- MPC22165-A-170
MPC22165-A-170
9mmx9.9mmx10mm, 170A, 2-Phase, High Power Density Intelli-ModuleTM with Qualified Higher Current Density
- Module AssemblyOpen Frame
- Vin (min) (V)4
- Vin (max) (V)16
- Vout (min) (V)0.5
- Vout (max) (V)2
- Iout (max) (A)170
- fsw (min) (kHz)600
- fsw (max) (kHz)1500
- Dimension WxL (mm)9x9.9
- Dimension (H) (mm)10
- Mounting TypeSurface Mount
- GradeIndustrial
- Dimension (H) (Max) (mm)10
The MPC22165-A-170 is a 2-phase, non-isolated, high-efficiency, step-down power module. It integrates driver MOSFETs (DrMOS) and inductors to provide high efficiency in a small footprint, which is ideal for server applications. The device has two independent outputs, which can be used separately or in parallel. It can achieve up to 170A (85A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC22165-A-170 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current sensing to monitor the inductor current (IL), and has temperature sensing to report the junction temperature (TJ).
The MPC22165-A-170 is available in an LGA-72 (9mmx9.9mmx10mm) package.
- Up to 170A of Continuous Output Current (IOUTx)
- Accu-SenseTM Current Sensing (CS)
- Temperature Sense
- Tri-State Pulse-Width Modulation (PWM) Signal Compatible
- Fault Reporting
- Typical Weight: 3.6g
- Available in an LGA-72 (9mmx9.9mmx10mm) Package
MPC22165-A-170-T
MPC22165-A-170 Resources
MPC22174-170PRODUCTDual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
USE CASE
MP5096PRODUCT5.5V, 1mΩ Low-RDS(ON) E-Fuse with Inrush Current Control and Current Monitoring
