- MPC22158-130
MPC22158-130
- Module AssemblyOpen Frame
- Vin (min) (V)3
- Vin (max) (V)16
- Vout (min) (V)0.5
- Vout (max) (V)2
- Iout (max) (A)130
- fsw (min) (kHz)600
- fsw (max) (kHz)1500
- Dimension WxL (mm)8x8
- Dimension (H) (mm)4
- Mounting TypeSurface Mount
- GradeIndustrial
- Dimension (H) (Max) (mm)4
The MPC22158-130 is a dual-phase, non-isolated, high-efficiency step-down power module. It integrates driver MOSFETs (DrMOS) and inductors to provide high efficiency and a small footprint, which is ideal for server applications.
The MPC22158-130 has two independent outputs, which can be used separately or in parallel. it can achieve up to 130A (65A/phase) of output current (IOUT) across a wide input voltage (VIN) range.
The MPC22158-130 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current sensing to monitor the inductor current (IL), and has temperature sensing to report the junction temperature (TJ).
The MPC22158-130 is available in an LGA-45 (8mmx8mmx4mm) package.
- Quiet SwitcherTM Technology (QST) Limits Peak Switching Voltages
- Wide 3V to 16V Input Voltage (VIN) Range
- Up to 130A of Output Current (IOUT)
- Temperature Sense
- Fault Reporting
- Typical Weight: 1.2g
- Available in an LGA-45 (8mmx8mmx4mm) Package
MPC22158-130-T
MPC22158-130 Resources
ARTIFICIAL INTELLIGENCE (AI) SOLUTIONAPPLICATION -
MPC22174-170PRODUCTDual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
USE CASE
