- Products
- Power Modules
- Intelli-Module
- MPC22175-130
MPC22175-130
- Module AssemblyOpen Frame
- Vin (min) (V)4
- Vin (max) (V)16
- Vout (min) (V)0.2
- Vout (max) (V)2
- Iout (max) (A)130
- fsw (min) (kHz)400
- fsw (max) (kHz)2000
- Dimension WxL (mm)9x9.9
- Dimension (H) (mm)4.75
- Mounting TypeSurface Mount
- GradeIndustrial
- Dimension (H) (Max) (mm)4.75
The MPC22175-130 is a dual-phase, non-isolated, high-efficiency step-down, transinductor voltage regulator (TLVR) power module. This Intelli-ModuleTM integrates Quiet SwitcherTM Technology (QSTTM), as well as driver MOSFETs (DrMOS) and TLVR inductors. All of this enables high efficiency and excellent transient performance in a small footprint, which is ideal for AI and server applications.
The MPC22175-130 has two outputs. Its pinout is compatible with a traditional 2-phase voltage regulator (VR) common footprint module. It can easily achieve several ICs in parallel layout and operation with the TLVR footprint, and can achieve up to 130A (65A/phase) of output current (IOUT) across a wide input voltage (VIN) range.
The device offers many features to simplify system design. It works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current-sensing to monitor the inductor current (IL), and has temperature sensing to report the junction temperature (TJ).
The MPC22175-130 is available in an LGA-72 (9mmx9.9mmx4.75mm) package.
- Up to 130A of Output Current (IOUT)
- Excellent Transient Performance
- Footprint Compatible with a 2-Phase Voltage Regulator (VR) Module
- Temperature Sense
- Fault Reporting
- Typical Weight: 2.3g
- Available in an LGA-72 (9mmx9.9mmx4.75mm) Package
MPC22175-130-T
MPC22175-130 Resources
ARTIFICIAL INTELLIGENCE (AI) SOLUTIONAPPLICATION -
MPC22174-170PRODUCTDual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
USE CASE
