- MPC24380-260
MPC24380-260
- Module AssemblyOpen Frame
- Vin (min) (V)3
- Vin (max) (V)8
- Vout (min) (V)0.5
- Vout (max) (V)2
- Iout (max) (A)260
- fsw (min) (kHz)500
- fsw (max) (kHz)1500
- Dimension WxL (mm)9x10
- Dimension (H) (mm)5
- Mounting TypeSurface Mount
- GradeIndustrial
- Dimension (H) (Max) (mm)5
The MPC24380-260 is a four-phase, non-isolated, high-efficiency, step-down Intelli-ModuleTM power module with Quiet SwitcherTM Technology (QSTTM). It integrates driver MOSFETs (DrMOS), inductors, and output capacitors to provide high efficiency and a small footprint, which is ideal for server applications.
The MPC24380-260 can achieve up to 260A (65A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC24380-260 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, provides Accu-SenseTM current-sensing to monitor the inductor current (IL), and provides temperature-sensing to report the junction temperature (TJ).
The MPC24380-260 is available in an LGA-54 (9mmx10mmx5mm) package.
- Wide 3V to 8V Input Voltage (VIN) Range
- Up to 260A of Continuous Output Current (IOUTx)
- Temperature Sense
- Fault Reporting
- Available in an LGA-54 (9mmx10mmx5mm) Package
MPC24380-260-T
MPC24380-260 Resources
ARTIFICIAL INTELLIGENCE (AI) SOLUTIONAPPLICATION -
MPC22174-170PRODUCTDual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
USE CASE
