- MP86884-3
MP86884-3
55A, 14V, Intelli-phase Solution (Integrated HS/LS FETs and Driver) w/ 3.3V PWM Logic in 6x6(mm) TQFN
MP86884-3 continues to be in production for existing customers. Please consider this alternative for new designs:
MP86945A
MP86945A
Intelli-PhaseTM Solution with Integrated High-Side and Low-Side FETs and Driver
- Wide 4.5V to 16V Operating Input Range
- 60A Output Current
- Current Sense: Accu-SenseTM
- Temperature Sense
- Accepts Tri-State PWM Signal
- Current-Limit Protection
- Fault Reporting
- Available in TQFN (4mmx5mm) Package
- Vin (min) (V)4.5
- Vin (max) (V)14
- Iout (max) (A)55
- Isw Limit (typ) (A)80
- Iin (Standby) (mA)0.06
- fsw (min) (kHz)100
- fsw (max) (kHz)1000
- trise (ns)3
- tfall (ns)8
- PWM Logic (V)3.3
- Package (mm)TQFN-34 (6x6)
- GradeCatalog
The MP86884 is a monolithic half-bridge with built-in internal power MOSFETs and gate drivers. It achieves 55A of continuous output current over a wide input supply range.
Integration of the driver and MOSFETS results in high efficiency due to optimal dead time control and parasitic inductance reduction.
The MP86884 is a Monolithic IC approach to drive up to 55A per phase. This very small 6mmx6mm TQFN device can operate from 100kHz to 1MHz.
This device works with tri-state output controllers. It also comes with a general-purpose current sense and temperature sense.
The MP86884 is ideal for server applications where efficiency and small size are a premium.
- Wide 4.5V to 14V Operating Input Range
- Simple Logic Interface
- 55A Output Current
- Built-In Switch for bootstrap
- Current Sense
- Temperature Sense
- Current Limit Protection
- Used for Multi-Phase Operation
- Available in 6mm x 6mm TQFN Package
- ROHS6 Compliant
MP86884DQKT-Z
MP86884-3 Resources
USE CASE
MP87563PRODUCTIntelli-PhaseTM Solution in a TLGA-33 (5.25mmx5mm) Package and LGA-33 (5.25mmx5mm) Package
MP86962PRODUCT80A, Radiation-Tolerant Intelli-PhaseTM DrMOS Solution in a TLGA-41 (5mmx6mm) Package
MP87190PRODUCT90A, Intelli-PhaseTM DrMOS Solution in a TLGA-41 (5mmx6mm) Package with Quiet SwitcherTM Technology and 5V PVCC
MP86992PRODUCT16V, 50A, Intelli-PhaseTM Solution in an LGA-41 (5mmx6mm) Package
