MP29816-C
- Number of Output Rail2
- Number of Phases16
- VCC (min) (V)3.1
- VCC (max) (V)3.5
- Iq (typ) (mA)50
- Ishutdown (typ) (mA)0.25
- fsw (min) (kHz)200
- fsw (max) (kHz)3000
- InterfacesAVSBus, PMBus
- Processor TypeASIC, CPU/GPU
- Package (mm)TQFN-56 (7x7)
- GradeCatalog
The MP29816-C is a highly integrated, digital multi-phase controller that comprises an advanced power solution for CPUs, GPUs, and systems-on-chip (SoCs) in a wide range of applications, including servers, datacenters, and consumer applications. This controller is dedicated to AVSBus protocols. The MP29816-C supports up to 16 phases in one rail or support 8+8 (maximum) phases in two-rail applications. Together with MPS’s Intelli-PhaseTM products, the MP29816-C provides a high-density, energy-efficient core power solution.
The device provides an on-chip non-volatile memory (NVM) to store and restore device configurations. Device configurations and fault parameters can be easily configured and monitored via the PMBus/I2C interface. The wide range of configurable parameters and multiple protection features enable the MP29816-C to support easily building an intelligent, robust system.
The MP29816-C adopts a unique, digital, multi-phase, nonlinear control method to provide excellent transient performance with minimal output capacitors. The unique simple compensation loop makes it easy to debug.
It is available in a TQFN-56 (7mmx7mm) package.
- Supports AVSBus Rev. 1.3
- PMBus/I2C Compliant (1MHz Bus Speed)
- Pin-Configurable AVSBus Address
- Pin-Configurable PMBus Address
- Built-In Non-Volatile Memory (NVM) to Store Configurations
- Supports a 200kHz to 3MHz Switching Frequency (fSW)
- Supports Auto-Slope Function
- Multi-Configuration Function Supports Up Six Different Applications
- Flexible Pulse-Width Modulation PWM Assignment for 2 Rails
- Flexible Output Current (IOUT) Sense via DrMOS IOUT Pins
- Automatic Phase-Shedding (APS) Function Improves Overall Efficiency
- Phase-to-Phase Active Current Balancing with Configurable Offsets for Thermal Balancing
- Input Voltage (VIN), Output Voltage (VOUT), Current, and Power Monitoring
- VIN Under-Voltage Lockout (UVLO), VOUT Over-Voltage Protection (OVP)/Under-Voltage Protection (UVP), Over-Current Protection (OCP), and Over-Temperature Protection (OTP) with No Action, Latch-Off, or Hiccup Options
- Intelli-PhaseTM Fault Diagnosis
- Auto-Records Voltage Regulator (VR) Fault Type to the NVM
- Digital Load-Line Regulation
- Overclocking Mode by Adding Offset to VOUT
- Password Lock for Accessing Registers
- Available in a TQFN-56 (7mmx7mm) Package
MP29816-CGQNT-xxxx-Z MP29816-CGQNT-xxxx-P MP29816-CGQNT-0000-Z MP29816-CGQNT-0000-P
MP29816-C Resources
POWER SOLUTION FOR 5GAPPLICATION -
POWER SOLUTION FOR NICAPPLICATION -
ARTIFICIAL INTELLIGENCE (AI) SOLUTIONAPPLICATION -
PROCESSOR CORE POWER CONTROLLERSPRODUCT CATEGORY -
MP2925PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface in TQFN-48 Package
MP2929PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface in TLGA-40 Package
MP2921PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface
MP2976PRODUCTDual-Loop, Digital, 1 + 1 Phase Controller with PMBus Interface for VR13.HC/AVSBus
MP29508PRODUCTDigital Multi-Phase Controller
MP2891PRODUCTDual-Loop, Digital, 16-Phase Controller with PWM-VID Interface
MP2882APRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus Interface for AVSBus
MP29436-APRODUCTTriple-Loop, Digital Multi-Phase Controller
MP29439-APRODUCTQuad-Loop, Digital Multi-Phase Controller
MP2985BPRODUCTDual-Loop, Digital, 8-Phase Controller with Flexible PWM Firing Order and PMBus Interface for VR14 and Earlier Protocols
MP29612-APRODUCTDual-Loop, Digital, 12-Phase Controller with SVI3 Interface
MP29608-APRODUCTDual-Loop, Digital, 8-Phase Controller with SVI3 Interface
MP2890PRODUCTDual-Loop, Digital, 20-Phase Controller with PWM-VID Interface
MPQ2931-AEC1PRODUCTDigital LLC Controller with PMBus/I2C Interface, AEC-Q100 Qualified
MP29540PRODUCTDigital, Multi-Phase Controller
MP2869APRODUCTDual-Loop, Digital, 16-Phase Controller with SVI3 Interface for AMD
MP2927PRODUCTTriple-Loop, Digital, Multi-Phase Controller with PMBus Interface for AVSBus
