MP29612-A
- Number of Output Rail2
- Number of Phases12
- VCC (min) (V)3.1
- VCC (max) (V)3.5
- Iq (typ) (mA)50
- Ishutdown (typ) (mA)2.5
- fsw (min) (kHz)200
- fsw (max) (kHz)3000
- InterfacesPMBus/I2C, SVI3
- Processor TypeSVI3 (Version 2) Compliant
- Package (mm)TQFN-48 (6x6)
- GradeCatalog
The MP29612-A is a dual-rail, digital, multi-phase controller that provides power for SVI3 core power. The device can work with MPS’s Intelli-PhaseTM products to complete the multi-phase voltage regulator (VR) solution with minimum external components. It can be configured to maximum 12-phase operation for rail 1, and maximum 6-phase operation for rail 2.
The controller provides an on-chip non-volatile memory (NVM) to store and restore device configurations. Device configurations and fault parameters can be easily configured or monitored via the PMBus/I2C interface. The MP29612-A can monitor and report the output current (IOUT) via the current-sense output of the Intelli-PhaseTM devices.
It is based on a unique, digital, multi-phase, nonlinear control to provide fast transient response with minimal output capacitors. With only one power loop control method for both steady state and load transient, power loop compensation is very easy to configure.
The MP29612-A is available in a TQFN-48 (6mmx6mm) package.
- Up to 12-Phase, 2-Output, Digital Controller
- SVI3 (Version 2) Compliant
- PMBus/I2C Compliant (1MHz Bus Speed)
- Pin-Configurable for PMBus Address
- Built-In Non-Volatile Memory (NVM) to Store Configurations
- 200kHz to 3MHz Switching Frequency (fSW)
- Automatic Loop Compensation
- Supports Multi-Configuration for 6 Different Applications
- Flexible Pulse-Width Modulation (PWM) Assignment for Two Rails
- Automatic Phase-Shedding (APS) to Improve Overall Efficiency
- Phase-to-Phase Active Current Balancing with Configurable Offsets for Thermal Balance
- Input Voltage (VIN), Output Voltage (VOUT), Current, and Power Monitoring
- Regulator Temperature Monitoring
- VIN Under-Voltage Lockout (UVLO), Output Over-Voltage Protection (OVP)/Under-Voltage Protection (UVP), Over-Current Protection (OCP), Over-Temperature Protection (OTP) with No Action, Latch-Off, or Hiccup Options
- Intelli-PhaseTM Fault Diagnosis
- Voltage Regulator (VR) Auto-Records Fault Type to the NVM
- Digital Load-Line Regulation
- Overclocking Mode by Adding Offset to VOUT
- Available in a TQFN-48 (6mmx6mm) Package
MP29612-AGQKT-xxxx-Z MP29612-AGQKT-xxxx-P MP29612-AGQKT-0000-Z MP29612-AGQKT-0000-P
MP29612-A Resources
POWER SOLUTION FOR 5GAPPLICATION -
POWER SOLUTION FOR NICAPPLICATION -
APPLICATION CONTENT MENUAPPLICATION -
PROCESSOR CORE POWER CONTROLLERSPRODUCT CATEGORY -
MP2925PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface in TQFN-48 Package
MP2929PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface in TLGA-40 Package
MP2921PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface
MP2976PRODUCTDual-Loop, Digital, 1 + 1 Phase Controller with PMBus Interface for VR13.HC/AVSBus
MP29508PRODUCTDigital Multi-Phase Controller
MP2891PRODUCTDual-Loop, Digital, 16-Phase Controller with PWM-VID Interface
MP2882APRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus Interface for AVSBus
MP29436-APRODUCTTriple-Loop, Digital Multi-Phase Controller
MP29439-APRODUCTQuad-Loop, Digital Multi-Phase Controller
MP2985BPRODUCTDual-Loop, Digital, 8-Phase Controller with Flexible PWM Firing Order and PMBus Interface for VR14 and Earlier Protocols
MP29608-APRODUCTDual-Loop, Digital, 8-Phase Controller with SVI3 Interface
MP2890PRODUCTDual-Loop, Digital, 20-Phase Controller with PWM-VID Interface
MPQ2931-AEC1PRODUCTDigital LLC Controller with PMBus/I2C Interface, AEC-Q100 Qualified
MP29540PRODUCTDigital, Multi-Phase Controller
MP29816-CPRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus and AVSBus Interface
MP2869APRODUCTDual-Loop, Digital, 16-Phase Controller with SVI3 Interface for AMD
MP2927PRODUCTTriple-Loop, Digital, Multi-Phase Controller with PMBus Interface for AVSBus
