MP29608-A
- Number of Output Rail2
- Number of Phases8
- VCC (min) (V)3.1
- VCC (max) (V)3.5
- Iq (typ) (mA)50
- Ishutdown (typ) (mA)2.5
- fsw (min) (kHz)200
- fsw (max) (kHz)3000
- InterfacesPMBus/I2C, SVI3
- Processor TypeASIC, PMBus Compliant, SVI3 (Version 2) Compliant
- Package (mm)TLGA-40 (5x5)
- GradeCatalog
The MP29608-A is a dual-rail, digital, multi-phase controller that provides power for SVI3 core power. The device can work with MPS’s Intelli-PhaseTM products to complete the multi-phase voltage regulator (VR) solution with minimum external components. It can be configured to maximum 8-phase operation for rail 1 and a maximum 4-phase operation for rail 2.
The controller provides an on-chip non-volatile memory (NVM) to store and restore device configurations. Device configurations and fault parameters can be easily configured or monitored via the PMBus/I2C interface. The MP29608-A can monitor and report the output current (IOUT) by sensing the current-sense output of the Intelli-PhaseTM devices.
It is based on a unique, digital, multi-phase, nonlinear control to provide fast transient response with minimal output capacitors. With only one power-loop control method for both steady state and load transients, power-loop compensation is very easy to configure.
The MP29608-A is available in a TLGA-40 (5mmx5mm) package.
- Up to 8-Phase, 2-Output, Digital Controller
- SVI3 (Version 2) Compliant
- PMBus/I2C Compliant (1MHz Bus Speed)
- Pin-Configurable PMBus Address
- Built-In Non-Volatile Memory (NVM) to Store Configurations
- 200kHz to 3MHz Switching Frequency (fSW)
- Automatic Loop Compensation
- Supports Multi-Configuration for 6 Different Applications
- Flexible Pulse-Width Modulation (PWM) Assignment for 2 Rails
- Automatic Phase-Shedding (APS) to Improve Overall Efficiency
- Phase-to-Phase Active Current Balancing with Configurable Offsets for Thermal Balance
- Input (VIN) and Output Voltage (VOUT), Current, and Power Monitoring
- Regulator Temperature Monitoring
- VIN Under-Voltage Lockout (UVLO), Output Over-Voltage Protection (OVP)/Under-Voltage Protection (UVP), Over-Current Protection (OCP), Over-Temperature Protection (OTP) with No Action, Latch-Off, or Hiccup Options
- Intelli-PhaseTM Fault Diagnosis
- Voltage Regulator (VR) Auto-Records Fault Type to the NVM
- Digital Load-Line Regulation
- Overclocking Mode by Adding Offset to VOUT
- Available in a TLGA-40 (5mmx5mm) Package
MP29608-AGLUT-xxxx-Z MP29608-AGLUT-xxxx-P MP29608-AGLUT-0000-Z MP29608-AGLUT-0000-P
MP29608-A Resources
POWER SOLUTION FOR 5GAPPLICATION -
POWER SOLUTION FOR NICAPPLICATION -
APPLICATION CONTENT MENUAPPLICATION -
PROCESSOR CORE POWER CONTROLLERSPRODUCT CATEGORY -
MP2925PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface in TQFN-48 Package
MP2929PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface in TLGA-40 Package
MP2921PRODUCTDual-Loop, Digital, Multi-Phase Controller for VR14.Cloud with PMBus Interface
MP2976PRODUCTDual-Loop, Digital, 1 + 1 Phase Controller with PMBus Interface for VR13.HC/AVSBus
MP29508PRODUCTDigital Multi-Phase Controller
MP2891PRODUCTDual-Loop, Digital, 16-Phase Controller with PWM-VID Interface
MP2882APRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus Interface for AVSBus
MP29436-APRODUCTTriple-Loop, Digital Multi-Phase Controller
MP29439-APRODUCTQuad-Loop, Digital Multi-Phase Controller
MP2985BPRODUCTDual-Loop, Digital, 8-Phase Controller with Flexible PWM Firing Order and PMBus Interface for VR14 and Earlier Protocols
MP29612-APRODUCTDual-Loop, Digital, 12-Phase Controller with SVI3 Interface
MP2890PRODUCTDual-Loop, Digital, 20-Phase Controller with PWM-VID Interface
MPQ2931-AEC1PRODUCTDigital LLC Controller with PMBus/I2C Interface, AEC-Q100 Qualified
MP29540PRODUCTDigital, Multi-Phase Controller
MP29816-CPRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus and AVSBus Interface
MP2869APRODUCTDual-Loop, Digital, 16-Phase Controller with SVI3 Interface for AMD
MP2927PRODUCTTriple-Loop, Digital, Multi-Phase Controller with PMBus Interface for AVSBus
