- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- ステップダウンコンバータ
- MPQ4385-AEC1
MPQ4385-AEC1
36V, 20A to 25A, Low-EMI, Synchronous Step-Down Converter with ZDPTM, AEC-Q100 Qualified
- 入力電圧(最小) (V)3.3
- 入力電圧 (最大) (V)36
- Iout (max) (A)25
- Vfb (V)0.8
- fsw(最大)(kHz)2500
- Control ModeZDP Control
- パッケージ(mm)TQFN-32 (5x6)
- グレードAutomotive
The MPQ4385-AEC1 is a configurable-frequency (200kHz to 2.5MHz), synchronous step-down switching regulator with an integrated, internal high-side MOSFET (HS-FET) and low-side MOSFET (LS-FET). It provides a highly efficient, 20A to 25A output current (IOUT) with fixed-frequency, zero-delay pulse-width modulation (PWM) control (ZDPTM) for an optimal transient response.
The wide 3.3V to 36V input voltage (VIN) range accommodates a variety of step-down applications in automotive environments. A 1.5μA shutdown-mode quiescent current (IQ) allows the MPQ4385-AEC1 to be used in battery-powered applications.
High power conversion efficiency across a wide load range is achieved by scaling down the switching frequency (fSW) under light-load conditions to reduce switching and gate driver losses. An open-drain power good (PG) signal indicates whether the output is within 95% to 105% of its nominal voltage.
Frequency foldback helps prevent inductor current (IL) runaway during start-up. Thermal shutdown provides reliable, fault-tolerant operation. A high duty cycle and low-dropout (LDO) mode are provided for automotive cold-crank conditions.
The MPQ4385-AEC1 is available in a TQFN-32 (5mmx6mm) package, and a high thermal conductivity package option is also offered to facilitate top-side cooling applications. It is available in AEC-Q100 Grade 1.
- Designed for Automotive Transients:
- 3.3V to 36V Input Voltage (VIN) Range
- Load Dump Up to 40V
- Low-Dropout (LDO) Mode with Soft Recovery
- Highly Scalable Family:
- 20A to 25A Output Current (IOUT) Versions in Pin-Compatible Family
- Multi-Phase Capable Up to 8 Phases
- Designed for High Performance and Reduced Component Overhead:
- Zero-Delay Pulse-Width Modulation (PWM) Control (ZDPTM) for Extremely Fast Transient Response and Fewer External Capacitors
- ±1% Output Accuracy, ±1% Power Good (PG) Accuracy
- Fixed or Adjustable Output Voltage (VOUT) Options
- Fixed Output: 0.8V, 1V, 1.2V, 1.8V, 3.3V, 3.8V, 4.5V, or 5V
- Adjustable Output Up to 13V
- Output Discharge from SW to GND
- 25ns Minimum On Time to Allow High Conversion Ratio
- High Efficiency for Increased Battery Life and Improved Thermals:
- 10μA Standby Current
- Advanced Asynchronous Modulation (AAM) Mode Increases Efficiency under Light Loads
- Integrated, Low Resistance High-Side MOSFET (HS-FET) and Low-Side MOSFET (LS-FET)
- Thin QFN Package with High Thermal Conductivity to Facilitate Top-Side Cooling
- Optimized for Low EMC/EMI:
- 200kHz to 2.5MHz Configurable Switching Frequency (fSW)
- Symmetric VIN Pinout Placement
- Low Noise at High Frequency Band Using Quiet-FETTM Advanced Switching Technology
- Synchronizable to an External Clock
- CISPR 25 Class 5 Compliant
- MeshConnectTM Package in a TQFN-32 (5mmx6mm) Package with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Document Available
MPQ4385GQJTE-xxxx-AEC1-Z MPQ4385GQJTE-xxxx-AEC1-P MPQ4385GQJTHE-xxxx-AEC1-Z MPQ4385GQJTHE-xxxx-AEC1-P
MPQ4385-AEC1 Resources
ヘッドライトアプリケーションヘッドライトは、どんな車両においても最も重要な機能安全の1つです。新しい機能ではありませんが、現在、ほとんどの新しい自動車モデルにはLEDヘッドライトが搭載されており、明るさが増し、効率が向上し、ヘッドライトの寿命が長くなりました。そしてもちろん、あらゆる車載アプリケーションと同様に、ヘッドライトの設計は、厳格な熱要件、ISO26262安全規格、およびEMI規制を満たす必要があります。 そのため、MPSではAEC-Q100認定製品の広範な製品ラインアップを提供しています。MPSの非常に効率的で柔軟なライティングソリューションには、ステップアップコンバータ、降圧、昇圧、および昇降圧LEDドライバが含まれます。これらの車載グレードの製品は、最高レベルの安全性と性能を提供すると同時に、市場投入までの時間を短縮します。 MPSの信頼性とコスト効率の高い製品は、次世代の車載用ヘッ...
フロントカメラ(同軸)アプリケーション -
ステップダウンコンバータ製品カテゴリ -
