- Products
- Power Modules
- Step-Down
- MPM3896-30
MPM3896-30
- Module AssemblyECP
- Vin (min) (V)2.8
- Vin (max) (V)6
- Vout (min) (V)0.3
- Vout (max) (V)2
- Regulated Outputs1
- Iout (max) (A)30
- Iq (typ) (mA)4
- fsw (min) (kHz)300
- fsw (max) (kHz)2000
- I2C InterfaceYes
- PGYes
- SSInternal
- Package (mm)ECLGA-29 (5x6x2.9)
- Dimension WxL (mm)5x6
- Dimension (H) (mm)2.9
- Mounting TypeSurface Mount
- GradeIndustrial
The MPM3896-30 is a fully integrated, stackable, synchronous buck module series with a PMBus interface. It offers a complete power solution that integrates a controller, half-bridge FET, and power inductor, offering excellent load and line regulation across a wide 2.8V to 6V input voltage (VIN) range and 0.3V to 0.9 x VIN output voltage (VOUT) range. The MPM3896-30 operates at high efficiency across a wide output current (IOUT) range.
The device adopts MPS’s proprietary, constant-on-time (COT) control, which provides ultra-fast transient response and minimizes the required output capacitance. The PMBus interface provides digital configurability and key parameter monitoring.
It also features rich protection functions, including over-current protection (OCP), over-voltage protection (OVP), under-voltage protection (UVP), and over-temperature protection (OTP).
The MPM3896-30 requires a minimal number of readily available external components, and is available in a compact ECLGA (5mmx6mm) package.
- Wide 2.8V to 6V Operating Input Voltage (VIN) Range:
- 3.5V to 6V without VDD33 Connected to 3.3V
- 2.8V to 3.5V with VDD33 Connected to 3.3V
- Adjustable Output Voltage (VOUT) from 0.3V to 0.9 x VIN
- 30A Continuous Output Current (IOUT)
- VOUT Remote Sense
- Lossless, Accurate On-Die Current-Sensing
- 300kHz to 2MHz Switching Frequency (fSW)
- Ultra-Fast Transient Response with Multi-Phase Constant-On-Time (MCOT) Control
- Tracking Function Available
- PMBus 1.3 Compliant
- Configurable via the PMBus:
- Load Line
- Compensation
- VOUT
- fSW
- Protection Threshold and Mode
- Built-In Multiple-Time Programmable (MTP) Memory to Store Custom Configurations
- Accurate Telemetry Including:
- VIN and VOUT
- IOUT
- Fault Report
- Temperature
- Available in a Compact ECLGA (5mmx6mmx2.9mm) Package
MPM3896GPJ-30-xxxx-T MPM3896GPJ-30-0000-T
MPM3896-30 Resources
OPTICAL MODULESAPPLICATIONOptical modules are optical transceivers used for high-speed data transmission, and are used anywhere larger amounts of data needs to be sent and received. From data centers to telecom, short or long range, optical modules are ideal for large, efficient data transfers. Optical modules can range in size and bandwidth, with the newest generation supporting up to 400GB/s. Due to the large amounts of ...
STEP-DOWNPRODUCT CATEGORY -
MPM3811PRODUCT2.3V-5.5V Input, 1A Power Modulein Small 2mmx2mmx1.6mm QFN Package
