- Products
- Power Modules
- Step-Down
- MPM3509B-AEC1
MPM3509B-AEC1
36V, 0.6A Module, Synchronous, Step-Down Converter with an Integrated Inductor, AEC-Q100 Qualified
- Module AssemblyEncapsulated
- Vin (min) (V)4
- Vin (max) (V)36
- Vout (min) (V)0.807
- Vout (max) (V)32.4
- Regulated Outputs1
- Iout (max) (A)0.6
- Iq (typ) (mA)0.6
- fsw (min) (kHz)410
- fsw (max) (kHz)2200
- I2C InterfaceNo
- PGYes
- SSInternal
- Package (mm)QFN-17 (3x5x1.6)
- Dimension WxL (mm)3x5
- Dimension (H) (mm)1.6
- Mounting TypeSurface Mount
- GradeAutomotive
The MPM3509B is a synchronous, rectified, step-down converter power module with built-in power MOSFETs, inductors, and capacitors. The MPM3509B offers a very compact solution and requires only four external components to achieve 0.6A of continuous output current with excellent load and line regulation over a wide input supply range. The MPM3509B operates with a 400kHz switching frequency to achieve a fast load transient response.
Full protection features include over-current protection (OCP) and thermal shutdown.
The MPM3509B eliminates design and manufacturing risks while dramatically improving time-to-market.
The MPM3509B is available in a space-saving QFN-17 (3mmx5mmx1.6mm) package.
- Complete Switch-Mode Power Supply
- Wide 4V to 36V Operating Input Range
- 0.6A Continuous Load Current
- 90mΩ/50mΩ Low RDS(ON) Internal Power MOSFETs
- Fixed 400kHz Switching Frequency
- 410kHz to 2.2MHz Frequency Sync
- Forced Continuous Conduction Mode (FCCM)
- Power Good (PG) Indicator
- Over-Current Protection (OCP) with Valley-Current Detection and Hiccup Mode
- Thermal Shutdown
- Output Adjustable from 0.807V
- CISPR25 Class 5 Compliant
- Available in a QFN-17 (3mmx5mmx1.6mm) Package
- Available in a Wettable Flank Package
MPM3509BGQVE-AEC1-P MPM3509BGQVE-AEC1-Z
MPM3509B-AEC1 Resources
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
STEP-DOWNPRODUCT CATEGORY -
Order
