- Products
- Automotive (AECQ Grade)
- Power Modules
- MPM3551C-AEC1
MPM3551C-AEC1
- Module AssemblyEncapsulated
- Vin (min) (V)3.3
- Vin (max) (V)36
- Vout (min) (V)0.8
- Vout (max) (V)12
- Iout (max) (A)3
- Isw Limit (typ) (A)5.8
- Iq (typ) (mA)1.2
- Vfb (V)0.8
- fsw (max) (kHz)2420
- PGYes
- SSInternal
- Max Duty Cycle (%)99.5
- Package (mm)QFN-20 (4x6)
- GradeAutomotive
- I2C InterfaceNo
- Mounting TypeSurface Mount
- Dimension (H) (mm)2.29
The MPM3551C-AEC1 is an easy-to-use, fully integrated, synchronous step-down power module with a built-in inductor and MOSFET switches. It can achieve up to 3A of continuous output current (IOUT), with excellent load and line regulation.
The wide 3.3V to 36V input voltage (VIN) range and 42V load dump tolerance accommodate a variety of step-down applications in automotive input environments. A 1μA shutdown mode quiescent current (IQ) allows the device to be used in battery-powered applications.
An open-drain power good (PG) signal indicates whether the output is within 94.5% to 105.5% of its nominal voltage.
Frequency foldback helps prevent inductor current (IL) runaway during start-up. Thermal shutdown provides reliable, fault-tolerant operation. A high-duty cycle and low-dropout (LDO) mode are provided for automotive cold-crank conditions.
The MPM3551C-AEC1 is ideal for a wide range of applications with constrained PCB areas. It is available in a QFN-20 (4mmx6mm) package.
- Survives 42V Load Dump Tolerance
- Supports 3.1V Cold-Crank Conditions
- Low-Dropout (LDO) Mode
- Up to 3A of Continuous Output Current (IOUT)
- Continuous Operation Up to 36V
- 1μA Shutdown Supply Current (ISD)
- -40°C to +150°C (Absolute Maximum) Operating Junction Temperature (TJ)
- High Performance for Improved Thermals:
- Integrated 70mΩ High-Side MOSFET (HS-FET) and 50mΩ Low-Side MOSFET (LS-FET)
- 65ns Minimum On Time (tON_MIN) and 50ns Minimum Off Time (tOFF_MIN)
- Optimized for EMC and EMI:
- Symmetric VIN Pinout
- Integrated 1μH Power Inductor
- CISPR25 Class 5 Compliant
- 2.2MHz Fixed Switching Frequency (fSW)
- Additional Features:
- Power Good (PG) Output
- Adjustable Output from 0.8V
- Fixed Output Options: 1V, 1.8V, 2.5V, 3V, 3.3V, 3.8V, or 5V
- Forced Continuous Conduction Mode (FCCM)
- Over-Current Protection (OCP) with Hiccup Mode
- Available in a QFN-20 (4mmx6mm) Package with Wettable Flanks
- Documents Available for MPSafeTM QM System Design
MPM3551CGQWE-AEC1-Z MPM3551CGQWE-AEC1-P
MPM3551C-AEC1 Resources
HEADLIGHTSAPPLICATIONHeadlights remain one of the most important functional safety features in any vehicle. While not a new feature, most new car models now feature LED headlights to provide increased brightness, better efficiency, and longer headlight lifespans. And of course, as with any automotive application, headlight designs must meet strict thermal requirements, ISO26262 safety standards, and EMC regulations. ...
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
POWER MODULESPRODUCT CATEGORY -
MPM3901-AEC1PRODUCT60V, 1A, Synchronous Step-Down Power Module with an Integrated Inductor, AEC-Q100 Qualified
MPM3551-AEC1PRODUCT36V, 3A, Low Quiescent Current, Synchronous Step-Down Module, AEC-Q100 Qualified
MPM3806-AEC1PRODUCT5.5V, 1A, Synchronous Step-Down Power Module, AEC-Q100 Qualified
MPM3807C-AEC1PRODUCT5.5V, 2A, 2.4MHz, Synchronous Step-Down Module, AEC-Q100 Qualified
MPM3807-AEC1PRODUCT5.5V, 2A, Synchronous Step-Down Power Module, AEC-Q100 Qualified
MPM3808C-AEC1PRODUCT6V, 3A, 2.4MHz, Synchronous Step-Down Module, AEC-Q100 Qualified
MPM3806C-AEC1PRODUCT5.5V, 1A, 2.4MHz, Synchronous Step-Down Module, AEC-Q100 Qualified
Order
