- Products
- Power Modules
- Step-Down
- mEZD72401A-E
mEZD72401A-E
mEZD72401A-E continues to be in production for existing customers. Please consider this alternative for new designs:
MPM3530GRF
MPM3530GRF
55V 3A Step-Down Power Module
- Efficiency up to 92.3%
- External Soft Start
- Over Current Protection
- Power Good Indication
- Module AssemblyOpen Frame
- Vin (min) (V)4.5
- Vin (max) (V)36
- Vout (min) (V)2.5
- Vout (max) (V)2.5
- Regulated Outputs1
- Iout (max) (A)1
- fsw (min) (kHz)400
- fsw (max) (kHz)400
- I2C InterfaceNo
- PGNo
- SSInternal
- Package (mm)SiP
- Dimension WxL (mm)10x20
- Dimension (H) (mm)1.6
- Mounting TypeSIP
- GradeIndustrial
The mEZD72401A-E is an open-frame, 4.5-36V input step-down power module with 1A continuous output current and 2.5V output voltage. It provides up to 87% peak efficiency.
- 4.5V to 36V Wide Operating Input
- 1A Load Current
- Over-Current Protection
- Over-Temperature Protection
- Open Design Files and BOM
mEZD72401A-E
mEZD72401A-E Resources
STEP-DOWNPRODUCT CATEGORY -
Order
