- mEZD71201A-A
mEZD71201A-A
mEZD71201A-A continues to be in production for existing customers. Please consider this alternative for new designs:
MPM3530GRF
MPM3530GRF
55V 3A Step-Down Power Module
- Efficiency up to 92.3%
- External Soft Start
- Over Current Protection
- Power Good Indication
- Module AssemblyOpen Frame
- Vin (min) (V)4.5
- Vin (max) (V)24
- Vout (min) (V)1
- Vout (max) (V)1
- Regulated Outputs1
- Iout (max) (A)1.2
- fsw (min) (kHz)400
- fsw (max) (kHz)400
- I2C InterfaceNo
- PGNo
- SSInternal
- Package (mm)SiP
- Dimension WxL (mm)10x20
- Dimension (H) (mm)1.6
- Mounting TypeSurface Mount
- GradeIndustrial
The mEZD71201A-A is an open-frame, 4.5-24V input step-down power module with 1.2A continuous output current and 1.0V fixed output. It provides up to 84% peak efficiency.
- 1A Load Current
- Over-Current Protection
- Over-Temperature Protection
- Open Design Files and BOM
mEZD71201A-A
mEZD71201A-A Resources
STEP-DOWNPRODUCT CATEGORY -
Order
