- MP6212-3
MP6212-3
3.3V/5V, Single-Channel 1A Current-Limited Power Distribution Switches with different Flag function
MP6212-3 continues to be in production for existing customers. Please consider this alternative for new designs:
MP5075L
MP5075L
5.5V, 1A, Low RDS(ON) Load Switch
- Integrated 80mΩ Low RDS(ON) MOSFETs
- Wide VIN Range from 3V to 5.5V
- <5µA Shutdown Current
- Typical 1.4A Current Limit
- Output Discharge Function
- Internal Fixed 450μs Soft-Start Time
- <200ns Short-Circuit Protection Response Time
- Thermal Protection
- Available in a SOT563 (1.6mmx1.6mm) Package
- Vin (min) (V)2.7
- Vin (max) (V)5.5
- Iout (max) (A)1
- Ilimit (A)1.5
- Iq (typ) (µA)90
- Channels1
- EnableActive Low
- Rds(on) (mΩ)90
- Output DischargeNo
- GradeCatalog
- Package (mm)MSOP-8E
The MP6211-3/MP6212-3 single-channel Power Distribution Switch features internal current limiting to prevent damage to host devices due to faulty load conditions. The MP6211-3/MP6212-3 Analog switch has 95mΩ on-resistance and operates from 2.7V to 5.5V input. It is available with guaranteed current limits, making it ideal for load switching applications. The MP6211-3/MP6212-3 has built-in protection for both over current and increased thermal stress. For over current, the device will limit the current by changing to a constant current mode. As the temperature increases as a result of short circuit, the device will shut off. The device will recover once the device temperature reduces to approx 120°C. The FLAG output of MP6211-3/MP6212-3 will report a fail mode (low level) when over current or over temperature is encountered. The FLAG will not change state when the input UVLO is triggered. The MP6211-3/MP6212-3 is available in 8-Pin MSOP with exposed pad, SOIC8 with exposed pad, and TSOT23-5 packages.
- 1A Continuous Current
- Accurate Current Limit
- 2.7V to 5.5V Supply Range
- 90µA Quiescent Current
- 95mΩ MOSFET
- Thermal-Shutdown Protection
- Under-Voltage Lockout
- 8ms FLAG Deglitch Time
- FLAG Won't Change State At Input UVLO Transition
- Reverse Current Blocking
- Active High & Active Low Options
- SOIC8E, MSOP8E
MP6212DH-3-Z MP6212DH-3-P MP6212DH-3-LF-Z MP6212DH-3-LF-P
MP6212-3 Resources
USB SWITCHESPRODUCT CATEGORY -
MPF52012PRODUCTSingle USB PD Controller for DRP and Sink Ports, Supports Firmware Updates and Advanced PDP Management
MP4501PRODUCT60V USB Type-C Port with OVP and IEC ESD Protector
MP5046PRODUCT60V, 5A E-Fuse with Configurable Current Limit and Reverse Current Protection
MP5061PRODUCT4.5V to 28V Current-Limit Switch with Low RDS(ON), Current Monitoring, and Soft Start
MP5029-CPRODUCTUSB Charging Port Controller with Current-Limit Switch, Supporting CDP, DCP, and QC3.0 Modes
MP5042PRODUCT2A, 28V E-Fuse with Adjustable Current Limit
MP5035PRODUCT2.9V to 22V, 50mA to 2A, Configurable Current-Limit Switch in a TSOT23-6 Package
MP62341PRODUCT3.3V/5V, Dual-Channel 1A Current-Limited Power Distribution Switches
MP62055PRODUCT3.3V/5V, Single-Channel 500mA Current-Limited Power Distribution Switch
MP5036PRODUCT12V, 0.4A to 5A, Current Limit Switch with 15V Over-Voltage Clamp in TSOT23 Package
MP5036APRODUCT5V, 0.4A to 5A Current Limit Switch with 5.75V Over-Voltage Clamp
MP5030DPRODUCTUSB Charging Port Controller with Load Detection Supporting CDP, DCP Modes
MP5030PRODUCTUSB Charging Port Controller with Current Limit Switch, Supporting Type-C 5V and QC 3.0 Modes
MP5030CPRODUCTUSB Charging Port Controller with Current Limit Switch, Supporting CDP, DCP, and Quick Charge 3.0 Modes
MP5034PRODUCTUSB Charging Port Controller Integrating Quick Charge 3.0 Protocol
MP62551PRODUCTPrecision Adjustable Current-Limited Power Distribution Switch
MP6233PRODUCT3.3V/5V, Dual-Channel 1.5A Current-Limited Power Distribution Switch
MP62550PRODUCTPrecision 60mA-1.7A Programmable Current-Limited Power Distribution Switch
MP62340PRODUCT3.3V/5V, Dual-Channel 1A Current-Limited Power Distribution Switches
MP62351PRODUCT3.3V/5V, Dual-Channel, 500mA Current-Limited Power Distribution Switches With Output Discharge
MP62071PRODUCT3.3V/5V, Single-Channel 0.8A Current-Limited Power Distribution Switch
MP5032PRODUCTQuick Charge 3.0 Controller with Integrated Current Limit Switch
MP4201PRODUCT100V, 25A, Synchronous, Bidirectional, Buck-Boost Controller with I2C, Battery Charging, and Adjustable OCP for USB EPR Power Delivery
MPF52001PRODUCTSingle USB PD Controller for Source Port Supporting Firmware Update and Advanced PDP Management
