The EVQ4233-VE-00A is an evaluation board designed to demonstrate the capabilities of the MPQ4233, a synchronous, four-switch, buckboost converter with integrated MOSFETs. The device can deliver up to 3A of output current (IOUT) and achieve excellent efficiency across a certain input voltage (VIN) supply range.
The MPQ4233-AEC1 is designed for USB power delivery (PD) and wireless charging applications. It can work well with an external PD controller or wireless charging controller through the I2C interface.
The MPQ4233-AEC1 is available in a small QFN-19 (4mmx5mm) package with wettable flanks. It is recommended to read the MPQ4233-AEC1 datasheet prior to making any changes to the EVQ4233- VE-00A.
もっと見る少なく表示
