The EVM4720-PA-00A evaluation board is designed to demonstrate the capabilities of the MPM4720, a high-efficiency, buck-boost power module with an integrated inductor.
The fixed 2MHz switching frequency (fSW) enables the use of small external components. Internal compensation and soft start (SS) minimize external component count. The MPM4720 uses current-mode control with a fixed pulse-width modulation (PWM) frequency for optimal stability and transient response.
The MPM4720 is available in a small ECLGA-14 (2.5mmx2.5mmx1.2mm) package.
It is recommended to read the MPM4720 datasheet prior to making any changes to the EVM4720-PA-00A.
もっと見る少なく表示
