Basic Principles
Electrochemical Reactions
Electrochemical processes, which include the transfer of electrons from one material to another, provide the basis for a battery's operation. In its most basic form, a battery turns chemical energy into electrical energy during discharge, which may then be utilized to power devices. Electricity is transformed back into chemical energy during charging. The cathode and anode electrodes, which are submerged in an electrolyte, are the sites of these electrochemical processes, which are crucial for a battery's operation.
An oxidation process at the anode results in the release of electrons. At the cathode, a reduction process takes place concurrently where electrons are received. We convert the passage of electrons between the anode and the cathode into electrical energy.
Components of a Battery: Electrodes, Electrolyte, Separator
Electrodes: The anode and the cathode are the two electrodes in a battery. The oxidation process occurs at the anode, which is regarded as the negative electrode. The reduction process takes place at the cathode, which is regarded as the positive electrode in contrast.
Electrolyte: Between the cathode and anode, electrical charge can move through the electrolyte. While the electrolyte in typical batteries is a liquid solution containing ions, it is a solid substance in solid-state batteries. To avoid internal short circuits, the electrolyte must be able to conduct ions while remaining electrically insulating.
Separator: The separator plays a crucial role in preventing a short circuit by preventing the cathode and anode from coming into direct contact with one another. It frequently consists of a porous substance that has been immersed in the electrolyte, and it must permit the passage of ions through it.
Electromotive Force and Cell Potential
Understanding the electromotive force (EMF) is essential to comprehending how batteries work. It speaks about the electrical potential difference that exists between a battery's two electrodes when there is no current flowing. It is, in other words, the highest voltage a battery is capable of supplying. EMF is closely tied to the electrochemical processes taking place in the battery since various materials and electrolytes will result in various potentials.
The cell potential is analogous to the EMF but takes into consideration the actual battery parameters, such as temperature and ion concentration in the electrolyte. It is the voltage that may be observed between a battery's terminals when the battery is being charged or discharged.
Understanding how various elements impact a battery's performance relies on the Nernst equation, which is frequently used to connect the cell potential to the concentration of reactants and products as well as temperature.
Battery Discharge and Charge Process
Electrochemical Reactions During Discharge
An electrochemical oxidation-reduction (redox) process takes place during a battery's discharge, which causes electrons to travel from the anode to the cathode through an external circuit. The battery's chemical energy is transformed into usable electrical energy through this process, which may be utilized to power devices.
At the anode, oxidation takes place, which means that while the active material releases electrons, electrons are also liberated. The positive ions go from the anode to the electrolyte as a result of this. On the other hand, a reduction process occurs at the cathode, where the active material absorbs electrons. The cathode accepts the electrons that were emitted at the anode after they have traveled through the external circuit. The electrolyte's positive ions move toward the cathode at the same time, ensuring charge neutrality. An electric current that may be utilized to power electronic devices is created by the movement of electrons across the external circuit.
Electrochemical Reactions During Charge
An external voltage source is used to apply a current in the opposite direction from the discharge process while the battery is being charged. By doing this, the electrochemical processes that took place during discharge are reversed, recharging the battery's chemical energy reserves.
The active material at the anode now undergoes a reduction process and absorbs electrons from the external circuit. On the other hand, an oxidation process takes place at the cathode, where the active substance releases electrons to the external circuit. As a result, positive ions move through the electrolyte from the cathode to the anode, balancing the charges inside the battery.
Controlling the voltage and current while charging is essential to avoid overcharging, which might result in gassing, heat production, and probable battery damage.
It's crucial to understand that not all electrochemical processes are completely reversible. Especially at high rates of charge or discharge or at very high temperatures, several adverse responses might happen. These adverse effects frequently lead to the loss of active material and gradual battery deterioration over time.
The electron flow during the charge and discharge operations is depicted in the following image:
Figure 3: Charge and Discharge processes
Energy Storage and Release
The Concept of Energy Density
An important factor in determining a battery's performance is its energy density. It is a measurement of how much energy can be kept in a battery of a certain mass or volume. Gravimetric energy density (measured in watt-hours per kilogram, Wh/kg) and volumetric energy density (measured in watt-hours per liter, Wh/L) are the two main ways that energy density is commonly stated.
Gravimetric energy density takes into account the battery's mass and is important for applications where weight is important, such as in portable electronics and electric cars. A battery is more lightweight and effective for these applications if it has a greater gravimetric energy density, which allows it to store more energy for the same weight.
On the other hand, volumetric energy density takes into consideration the area that the battery takes up. This is a crucial factor to take into account for applications that have limited capacity, such those seen in smartphones or other small devices. A battery is more compact if it has a greater volumetric energy density, which means it can store more energy in a given volume.
How Energy is Stored and Released in a Battery
Electrochemical processes are used in batteries to transform electrical energy into chemical energy. An external voltage source generates a current that moves electrons from the cathode to the anode of the battery as it charges. As was mentioned before, this flips the discharge processes such that oxidation takes place at the cathode and reduction occurs at the anode. Energy is stored inside the battery via the chemical bonds created during these processes.
The chemical energy is transformed back into electrical energy after being discharged. The anode's oxidation releases electrons, which go to the cathode's reduction through an external circuit. An electric current made up of this electron flux can be used to power various devices.
The materials used for the electrodes and electrolyte, the battery design, the rate of charge and discharge, and the operating circumstances, such as temperature and state of charge, all have an impact on the efficiency and capacity of energy storage and release in batteries.
