RFSoC gen2/gen3 Reference Design using Modules
AMD Xilinx part numbers
  • XCZU39DR
  • XCZU43DR
  • XCZU46DR
  • XCZU47DR
  • XCZU48DR
  • XCZU49DR
Contact Us
Overview
  • 12Vin design (no intermediary regulator required)
  • Design can be easily scaled/modified for customer requirements
  • Common use of parts allow step and repeat for ease of design
  • Easy to use Quad PMIC module (25A per output) provides flexibility, high efficiency and fast transient response
  • MPM modules are fully factory tested solutions and require minimum engineering
  • MPM modules include inductors
  • Total system efficiency ~89%
  • Total solution size ~2.0 sq.in including input & output Caps
MPS Products Used
Part Number Quantity Description
MPM82504 1 16V, Quad 25A, Scalable, DC/DC Power Module with PMBus
MPM3683-7 6 2.7V-16V, 8A, Step-Down Power Module in QFN (7x7x4mm) Package
MPM3632C 4 18V Input, 3A Module, Synchronous, Forced CCM, Step-Down Converter with Integrated Inductor
MP8904 2 500mA Linear Regulator
MCS1802 5 Cost Effective Hall Effect-Based Linear Current Sensor IC, 3.3V Supply
MP20075 3 3A, DDR Termination Regulator
EVREF0102A 1 The EVREF0102A is the analog power module for the Zynq UltraScale+ RFSoC characterization kit. The EVREF0102 analog power module provides an ultra low-noise power supply for high-speed data converters
