- Products
- Inductors
- Molded Inductors
- MPL-AY Molded
- MPL-AY1050
- MPL-AY1050-100
MPL-AY1050-100
- Series DescriptionMolded
- L (µH)10
- RDC (typ) (mΩ)19
- IR (40K) (A)7.8
- Isat (30%) (A)12
- Size Code1050
- A Dimension (L) (mm)11.0
- B Dimension (W) (mm)10.0
- C Dimension (H) (mm)4.80
- Operating Temp (max) (℃)155
- Mounting TypeSMD
- Size 11mmx10mmx4.8mm
- Molded Construction
- Low Audible Noise
- Soft Saturation
- Stable Over High Temperatures
- Max Operating Temp +155°C
MPL-AY1050-100
MPL-AY1050-100 Resources
HOW TO CALCULATE A BUCK CONVERTER'S INDUCTANCEARTICLEIn the buck circuit, the inductor design is a key element that is closely related to system efficiency, the output voltage ripple (∆VOUT), and loop stability. This article discusses how to calculate the inductance of a buck converter using the MPQ2314 as well as key parameters including the rising current of the inductor temperature, saturation current DC resistance, operating frequency, and magne...
MPL-AY1050PRODUCT CATEGORY -
MOLDED INDUCTORSPRODUCT CATEGORY -
MPL-AT2512-2R2CPRODUCT2.2μH, Low-Profile Molded Inductor
MPL-AT2512-R47CPRODUCT0.47μH, Low-Profile Molded Inductor
MPL-SR7345-101PRODUCT100μH Shielded Inductor
MPL-SR7345-150PRODUCT15μH Shielded Inductor
MPL-AT2512-4R7PRODUCTLow-Profile Molded Inductor 4.7μH
Order
