- Products
- Inductors
- Molded Inductors
- MPL-AL Molded Low Resistance
- MPL-AL6050
- MPL-AL6050-R82
MPL-AL6050-R82
- L (µH)0.82
- RDC (typ) (mΩ)3.9
- IR (40K) (A)16.9
- Isat (30%) (A)24
- Size Code6050
- A Dimension (L) (mm)6.60
- B Dimension (W) (mm)6.40
- C Dimension (H) (mm)4.80
- Operating Temp (max) (℃)155
- Mounting TypeSMD
- Size 6.6mmx6.4mmx4.8mm
- Low DCR
- Low AC Losses
- Low Audible Noise
- Molded Construction
- Soft Saturation
- Stable Over High Temperatures
- Max Operating Temp +155°C
MPL-AL6050-R82
MPL-AL6050-R82 Resources
WHEN IS IT BENEFICIAL TO PLACE A COPPER LAYER BENEATH DC/DC POWER SUPPLIES?ARTICLEEngineers often disagree on whether the inductive bottom of DC/DC power supplies should be laid with copper. The first argument is that laying copper under the inductor produces eddy currents on the ground plane. As a result, the eddy current affects the power inductor’s inductance and increases the system loss, and the ground plane noise impacts other high-speed signals. The second argument is th...
MPL-AL6050PRODUCT CATEGORY -
MOLDED INDUCTORSPRODUCT CATEGORY -
MPL-AT2512-2R2CPRODUCT2.2μH, Low-Profile Molded Inductor
MPL-AT2512-R47CPRODUCT0.47μH, Low-Profile Molded Inductor
MPL-SR7345-101PRODUCT100μH Shielded Inductor
MPL-SR7345-150PRODUCT15μH Shielded Inductor
MPL-AT2512-4R7PRODUCTLow-Profile Molded Inductor 4.7μH
Order
