EV2629-QC-00A
4.5A I2C Controlled SW CHARGER With NVDC Power Path and USB OTG EV Board
EV2629-QC-00A continues to be in production for existing customers. Please consider this alternative for new designs:
EV2723A-QC-00A
Active
EV2723A-QC-00A
Active
5V, 3A, I2C-Controlled, Switching Charger with NVDC Power Path, USB OTG, and Enhanced ADC Evaluation Board
- 3.7V to 5.5V Operating Input Voltage (VIN) Range
- Up to 22V Sustainable Voltage
- 3A, 1.35MHz, High-Efficiency Buck Charger:
- Up to 92% Charge Efficiency at 3A Charge Current (ICHARGE)
- Auto-Detection for USB SDP, CDP, DCP, and Non-Standard Adapters
- USB OTG with 4.8V to 5.5V Adjustable Output Voltage (VOUT), Up to 93% Efficiency with Up to 1.5A VOUT
- NVDC Power Path Management:
- Instant-On Works with No Battery or Deeply Discharged Battery
- Ideal Diode Operation in Battery Supplement Mode
- High Battery Discharge Efficiency for Up to 8.5A with 14mΩ BATFET
- I2C Port for Flexible System Parameter Setting and Status Reporting
- Fully Integrated Power MOSFETs and Current Sensing
- Dedicated DISC Pin for Shipping Mode and System Reset
- 13μA Low Battery Leakage Current in Shipping Mode
- Integrated ADC for Monitoring VIN, Input Current (IIN), ICHARGE, Battery Voltage (VBATT), System Voltage, and Battery Temperature
- Charging Status Indicator
- Safety Features:
- Configurable JEITA for Battery Temperature Protection
- Battery Charging Safety Timer
- Thermal Regulation
- Thermal Shutdown
- Watchdog Monitoring I2C Operation
- Input/System Over-Voltage Protection (OVP)
- Available in a QFN-26 (3.5mmx3.5mm) Package
EV2629-QC-00A
