ZYNQ UltraScale+ RFSoC gen1
Smallest Size Power Management Reference Design
REFERENCE DESIGN
AMD Xilinx part numbers
- XCZU21DR
- XCZU25DR
- XCZU27DR
- XCZU28DR
- XCZU29DR
- XQZU21DR
- XQZU28DR
- XQZU29DR
Overview
- 12Vin design (no intermediary regulator required)
- Design can be easily scaled/modified for customer requirements
- Common use of parts allow step and repeat for ease of design
- Easy to use 2x Parallelable modules (40A VCCINT) for high efficiency and fast transient response
- MPM modules are fully factory tested solutions and require minimum engineering
- MPM modules include inductors
- Total system efficiency ~87%
- Total solution size ~2.0 sqin including input & output Caps
MPS Products Used
Part Number | Quantity | Description |
MPM3695-25 | 3 | 16V, 20A, Scalable DC/DC Power Module with PMBus |
MPM3632C | 9 | 18V Input, 3A Module, Synchronous, Forced CCM, Step-Down Converter with Integrated Inductor |
MPM3683-7 | 1 | 2.7V-16V, 8A, Step-Down Power Module in QFN (7x7x4mm) Package |
MPM3606A | 2 | 21V Input, 0.6A Module Synchronous Step-down Converter with Integrated Inductor and PG pin |
EVREF0102A | 1 | The EVREF0102A is the analog power module for the Zynq UltraScale+ RFSoC characterization kit. The EVREF0102 analog power module provides an ultra-low-noise power supply for high-speed data converters |
