The MV300 is a MagVectorTM 3D magnetic sensor. It has two available test boards using either an I2C communication interface or a serial peripheral interface (SPI) communication interface. The MV300 test board with I2C communication is called the TBMV300-Q-LT-I2C. The MV300 test board with SPI communication is called the TBMV300-Q-LT-SPI. These test boards are designed to work with the EVKT-MV-RP-PICO evaluation kit and the MagVector Evaluation App Software. It is also possible to use these test boards directly with any microcontroller (MCU) that has a 3.3V I2C or SPI interface.
Show moreShow less
Forgot Password
Log in to continue
myMPS+
