EV3021DQ-00A
1x, 1.5x, 2x Auto-Adjust Charge Pump White LED Backlight Evaluation Board
EV3021DQ-00A
EV3021DQ-00A continues to be in production for existing customers. Please consider this alternative for new designs:
EV3320A-Q-00A
Active
EV3320A-Q-00A
Active
4-Channel, Charge Pump RGB LED Driver with Digital Interface Evaluation Board
  • 1.8V to 5.5V Input Voltage (VIN) Range
  • 5.5V Maximum Output Voltage (VOUT)
  • 4 Channels, Max 51mA/Channel
  • Enable/Disable for Each Channel
  • Internal, Self-Adaptive Charge Pump
  • Charge Pump Auto-Transfer Rate: 1x, 1.5x, and 2x
  • 8-Bit Analog Dimming for Each Channel
  • 10-Bit Pulse-Width Modulation (PWM) Dimming for Each Channel
  • Configurable PWM Dimming Frequency (fPWM)
  • 400kHz Compatible Digital Interface
  • Configurable Phase Shift
  • High Efficiency
  • LED Open Protection and LED Short Protection
  • Over-Voltage Protection (OVP)
  • Over-Temperature Protection (OTP)
  • Available in a QFN-14 (2mmx2mm) Package
EV3021DQ-00A
    $25.00 /unit
