The EVKT-MP2760 is an evaluation kit for the MP2760. The board is designed to demonstrate the capabilities of the MP2760, a buck-boost narrow-voltage DC (NVDC) charger IC for battery packs with 1 cell to 4 cells in series.
The device accepts a wide 4V to 22V input voltage (VIN) range to charge the battery and power the load connected on the SYS pin. It also supplies a wide 3V to 21V voltage range at the IN pin when source mode is enabled, which is compliant with USB power delivery (PD) specifications.
Show moreShow less
Forgot Password
Log in to continue
myMPS+
