EV8869W-L-00A
High Efficiency, 12A, 18V, Synchronous Step-Down Converter with I2C Interface Evaluation Board
EV8869W-L-00A continues to be in production for existing customers. Please consider this alternative for new designs:
EV8869S-L-00A
Active
EV8869S-L-00A
Active
High Efficiency,12A,18V, Synchronous Step-Down Converter with I²C Interface
- Vout Adjustable up to 5.5V using FB pin
- Wide 2.85V-to-18V Operating Input Range
- 12A Continuous/15A Peak Output Current
- 1% Internal Reference Accuracy
- I2C Programmable Output Range from 0.6V to 1.108V in 4mV Steps with Slew Rate Control
- 5% Accuracy Output Voltage and Output Current Read Back Via I2C
- Selectable PFM/PWM Mode and Adjustable Frequency & Current Limit Through I2C
- 4 Different I2C Address Selectable
- External Soft Start
- Open DrainPowerGood Indication
- Output Over Voltage Protection
- Hiccup/Latch off OCP Protection
- QFN-14(3mmx4mm) Package
Order
