The MP3336 is a dual-channel and high-power flash LED driver with very compact package. It can drive up to 2A in flash mode for each LED. It is usually applied for camera phones to improve image and video quality in low light environment. The device operates in1/2/3/4MHz synchronous, current-mode PWM boost converter to regulate the LED current with two high current source. The MP3336 provides an optimized solution for smaller PCB space and higher efficiency.
The MP3336 features standard I2C interface, dual LED channels, rich protection modes and high power density and performances. It supports flash/assist/torch/indicator/5V DC modes.
The cathodes of the dual flash LED are referenced to GND, which is better for layout to improve thermal performance. It is available in WLCSP20-1.6X2.0mm package.
Show moreShow less
Forgot Password
Log in to continue
myMPS+
Standby/Flash/Assist/Torch/Indicator/5V DC Modes Flash Mode: Up to 2A/Ch Programmable Current with +/-7% Accuracy for Each LED, 7.84mA/Step Assist/Torch Mode: Up to 319mA/Ch Programmable Current with +/-7% Accuracy for Each LED, 1.25mA/Step Indicator Mode: Work In 31.5kHz PWM Dimming Mode With 2/16, 3/16, 4/16, 5/16 Duty Cycle Used for Blinking and 128/256/512ms Selectable Blinking Time 5V DC Mode: Output Constant 5V DC Voltage
1A to 4.2A Programmable Input DC Current Limit Protection
