- Products
- Inductors
- Semi-Shielded Inductors
- MPL-SE4030
- MPL-SE4030-150
MPL-SE4030-150
- Series DescriptionSemi-Shielded
- L (µH)15
- RDC (typ) (mΩ)185
- IR (40K) (A)1.4
- Isat (30%) (A)1.8
- Size Code4030
- A Dimension (L) (mm)4.0
- B Dimension (W) (mm)4.0
- C Dimension (H) (mm)3.0
- Operating Temp (max) (℃)125
- Mounting TypeSMD
- Size 4mmx4mmx3mm
- Semi-Shielded Construction
- Low DCR
- Low Stray Field
- Max Operating Temp +125°C
MPL-SE4030-150
MPL-SE4030-150 Resources
WHEN IS IT BENEFICIAL TO PLACE A COPPER LAYER BENEATH DC/DC POWER SUPPLIES?ARTICLEEngineers often disagree on whether the inductive bottom of DC/DC power supplies should be laid with copper. The first argument is that laying copper under the inductor produces eddy currents on the ground plane. As a result, the eddy current affects the power inductor’s inductance and increases the system loss, and the ground plane noise impacts other high-speed signals. The second argument is th...
MPL-SE4030PRODUCT CATEGORY -
SEMI-SHIELDED INDUCTORSPRODUCT CATEGORY -
MPL-AT2512-2R2CPRODUCT2.2μH, Low-Profile Molded Inductor
MPL-AT2512-R47CPRODUCT0.47μH, Low-Profile Molded Inductor
MPL-SR7345-101PRODUCT100μH Shielded Inductor
MPL-SR7345-150PRODUCT15μH Shielded Inductor
MPL-AT2512-4R7PRODUCTLow-Profile Molded Inductor 4.7μH
Order
