EVKT-MACOM
MagAlpha Communication Kit to Connect to Sensor Test Boards (TMBA) and Rotary Knob Kit, Requires Macom App Software
EVKT-MACOM continues to be in production for existing customers. Please consider this alternative for new designs:
EVKT-MagAlpha-MagDiff
Active
Active
The EVKT-MagAlpha-MagDiff is a MagAlpha communication kit that connects to the sensor test boards (TMBA) and rotary knob kit, and requires Macom App Software.
- USB Interface
- RP2040: 32-Bit Dual ARM Cortex-M0+ Microcontroller (MCU) from Raspberry Pi
- Connectors Compatible with MagAlpha and MagDiff Tests Boards (TBMA)
- Supports Serial Peripheral Interface (SPI) and I2C Interface
- Connection for a Reference Optical Encoder (Supports 5V or 3.3V) with Footprints to Add Pull-Up Resistors or RC Low-Pass Filters If Needed
- Correction Table Computation and Configuring when Used Alongside the GUI or Python Library
