AC DC Quick Search Tool
Input Voltage
Vin Max > Vin Min
Value not accepted
Value not accepted
Recommended for Po > 65W
Voltage Breakdown
Value not accepted
Output Voltage
*Insert Current and Voltage values
Calculated Power
Value not accepted
Value not accepted
Value not accepted
Value not accepted
0
Error
0
Error
0
Error
Topology
Value not accepted
Qg is the amount of charge
Availabe if any Vo <= 20V and Io <= 3.5A
Save PCB space
Non Isolated selected
Search
Filters:
Filters Object:
Number of Original Products: 178
Number of Filtered Products: 178
| name | vinminvac | vinmaxvac | vccmaxv | vccminv | active_pfc | internal_mosfet | vbrv | poutmaxw | isolated_llc | secondary_synchronous_rectific | regular_mosfet | mosfet_with_large_qg | single_channel | switchingfreqkhz | dual_channel | isolated_flyback | high_side_rectification | low_side_rectification | discrete_drive | ideal_diode | isolated | non_isolated | iouta | vouta |
Attribute Sets:
1278 - AC-DC Power Conversion > HV Smart LDO Regulators Less than 1W
1279 - AC-DC Power Conversion > Flybacks > Primary-Side Regulation
1281 - AC-DC Power Conversion > Flybacks > Secondary-Side Regulation
1283 - AC-DC Power Conversion > LED Lighting & Illumination > AC-DC Isolated > PFC, No TRIAC Dimming
1285 - AC-DC Power Conversion > Fluorescent Lighting
1287 - AC-DC Power Conversion > LED Lighting & Illumination > AC-DC Non-Isolated > PFC, No TRIAC Dimming
1289 - AC-DC Power Conversion > LED Lighting & Illumination > DC-DC Lighting > Vin_max Less than 44V
1296 - AC-DC Power Conversion > Power Savers
1359 - AC-DC Power Conversion > PFC/LLC Combo Controller
1378 - AC-DC Power Conversion > HV Buck Regulators Less than 10W
1379 - AC-DC Power Conversion > LED Lighting & Illumination > AC-DC Isolated > No PFC, No TRIAC Dimming
1380 - AC-DC Power Conversion > LED Lighting & Illumination > AC-DC Isolated > PFC, TRIAC Dimming
1381 - AC-DC Power Conversion > LED Lighting & Illumination > AC-DC Non-Isolated > No PFC, No TRIAC Dimming
1382 - AC-DC Power Conversion > LED Lighting & Illumination > DC-DC Lighting > Vin_max Less than 24V
1383 - AC-DC Power Conversion > LED Lighting & Illumination > DC-DC Lighting > Vin_max Greater than 44V
1384 - AC-DC Power Conversion > LED Lighting & Illumination > Protection
1385 - AC-DC Power Conversion > PFC Controllers > PFC Boost/Flyback
1386 - AC-DC Power Conversion > LLC with 600V Half-Bridge Drivers
1387 - AC-DC Power Conversion > Synchronous Rectifiers > Synchronous Rectifiers Flyback Topology
1388 - AC-DC Power Conversion > Synchronous Rectifiers > Synchronous Rectifiers LLC Topology
1422 - AC-DC Power Conversion > LED Lighting & Illumination > AC-DC Non-Isolated > PFC, TRIAC Dimming
No products found matching your criteria. Showing similar products outside your range.
Load More
No more parts left for display.
