EV8048DQK-00A
新設計には使用不可
22V, 4A Quad Channel Power Half-Bridge Evaluation Board
  • 個数 価格
    ¥8,148.75 /単位
4~7営業日程度で到着
配送料1注文につき5ドルのみ
評価ボード詳細をご覧ください。
エンジニアにコンタクト、もしくは見積もり入手
製品説明
The EV8048DQK-00A is the evaluation board for the MP8048, a configurable dual channel full-bridge or quad channel half-bridge.
The MP8048 features a low current shutdown mode, standby mode, input under voltage protection, current limit, thermal shutdown and fault flag signal output. Each full-bridge can be driven independently as stereo single ended audio amplifiers, or driven complementary in a bridge tied load (BTL) audio amplifier configuration. All channels of drivers interface with standard logic signals.
製品の特長
  • ±4A Peak Current Output
  • Up to 600kHz Switching Frequency
  • Protected Integrated Power 200mΩ Switches
  • 30ns Switch Dead Time
  • All Switches Current Limited
  • Under Voltage Protection
  • Thermal Protection
  • 3.4mA Operation Current
  • Fault Output Flag
  • Single Ended Output Power: 8W/Channel, at  22V, 8Ω Load
  • Bridge Tied Load Output Power: 30W/Channel, at 22V, 8Ω Load
パラメータ
22V, 4A Quad-Channel Half-Bridge / Dual-Channel Full-Bridge Power Amplifier
The MP8048 is a configurable dual channel full-bridge or quad channel half-bridge that can be configured as the output stage of a Class-D audio amplifier. Each full-bridge can be driven independently as stereo single ended audio amplifiers or driven complementary in a bridge tied load (BTL) audio amplifier configuration.
The MP8048 features a low current shutdown mode, standby mode, input under voltage protection, current limit, thermal shutdown and fault flag signal output. All channels of drivers interface with standard logic signals.
The MP8048 is available in a 40 lead QFN 6X6 package.
すべてのMPS部品は鉛フリー、ハロゲンフリーで、RoHS指令に準拠しています。詳細については、環境セクションを参照してください。
