EV6908-S-01A
アクティブ
High Efficiency Synchronous Rectification EV Board
  • 個数 価格
    ¥2,716.25 /単位
4~7営業日程度で到着
配送料1注文につき5ドルのみ
評価ボード詳細をご覧ください。
エンジニアにコンタクト、もしくは見積もり入手
製品説明
The MP6908 is a low-drop diode emulator IC that, when combined with an external switch, replaces Schottky diodes in high-efficiency flyback converters. The MP6908 regulates the forward drop of an external synchronous rectifier (SR) MOSFET to about 40mV, which switches off once the voltage becomes negative.
The MP6908 can generate its own supply voltage for battery charging applications with a low output voltage or high-side rectification applications. Programmable ringing detection circuitry prevents the MP6908 from turning on falsely during discontinuous conduction mode (DCM) and quasi-resonant operation.
EV6908-S-01A is the evaluation board for MP6908.
製品の特長
  • Wide Output Range down to 0V
  • No Need for Auxiliary Winding for High-Side or Low-Side Rectification
  • Ringing Detection Prevents False Turn-On during DCM and Quasi-Resonant Operations
  • Works with Standard and Logic Level SR MOSFETs
  • Compatible with Energy Star
  • ~30ns Fast Turn-Off and Turn-On Delay
  • ~100µA Quiescent Current
  • Supports DCM, CCM, and Quasi-Resonant Operations
  • Supports both High-Side and Low-Side Rectification
  • TSOT23-6 Package Available
パラメータ
Fast Turn-Off Intelligent Rectifier with No Need for Auxiliary Winding
The MP6908 can generate its own supply voltage for battery charging applications with potential low output voltage, and at short circuit output condition, or for high-side SR configuration. Programmable ringing detection circuitry prevents the MP6908 from turning on falsely at Vds oscillations during discontinuous conduction mode (DCM) and quasi-resonant operation.
The MP6908 is available in a space-saving TSOT23-6 package.
The MP6908A is a low-drop diode emulator IC that, when combined with an external switch, replaces Schottky diodes in high-efficiency flyback converters. The MP6908A regulates the forward drop of an external synchronous rectifier (SR) MOSFET to about 40mV, which switches off once the voltage becomes negative.
The MP6908A can generate its own supply voltage for battery charging applications with a potential low output voltage. The MP6908A can also generate this voltage at short-circuit output conditions or high-side SR configurations. Programmable ringing detection circuitry prevents the MP6908A from turning on falsely at VDS oscillations during discontinuous conduction mode (DCM) and quasi-resonant operation.
The MP6908A is available in a space-saving TSOT23-6 package.
Fast Turn-Off Intelligent Rectifier with No Auxiliary Winding Requirement
The MP6908L is a low-drop diode emulator IC. When combined with an external switch, the MP6908L can replace Schottky diodes in high-efficiency flyback converters. The MP6908L regulates the forward drop of an external synchronous rectifier (SR) MOSFET to about 40mV, then switches off once the voltage becomes negative.
The MP6908L can generate its own supply voltage for battery charging applications that can have low output voltage or short-circuit output conditions, as well as high-side SR configuration. Configurable ringing detection circuitry prevents the MP6908L from false turn-off after VDS oscillates in discontinuous conduction mode (DCM), or during quasi-resonant operation.
The MP6908L is available in a space-saving TSOT23-6 package.
すべてのMPS部品は鉛フリー、ハロゲンフリーで、RoHS指令に準拠しています。詳細については、環境セクションを参照してください。
