- Products
- Automotive (AECQ Grade)
- USB Charging Port
- MPQ4253A-AEC1
MPQ4253A-AEC1
36V, Step-Down Converter, Supports One Type-A, One Type-C Dual USB Charging Ports for Automotive, AEC-Q100 Qualified
- Vin (min) (V)6
- Vin (max) (V)36
- Iout (max) (A)6
- Iq (typ) (mA)0.54
- fsw (max) (kHz)1000
- Vfb (V)1
- Control ModeCurrent Mode
- Package (mm)QFN-26 (5x5)
- GradeAutomotive
- Regulated Outputs2
- Vout (min) (V)5.1
- Vout (max) (V)5.3
- Isw Limit (typ) (A)12
- Max Duty Cycle (%)99
The MPQ4253A-AEC1 integrates a monolithic, step-down, switch-mode converter with two USB current-limit switches and charging port identification circuitry for each port. The MPQ4253A-AEC1 achieves up to 6A of output current (IOUT), with excellent load and line regulation across a wide input supply range.
The USB outputs are fixed as one Type-A port and one Type-C port. Each USB switch is current-limited. The USB1 port supports USB Type-C 5V @ 3A DFP mode. The USB2 port supports DCP schemes for battery charging specification (BC1.2), Apple divider 3 mode, and 1.2V/1.2V mode, eliminating the need for outside user interaction. The MPQ4253A-AEC1 buck and USB2 output is always on if EN is high. The USB1 port capability automatically changes to 1.5A when USB2 detects that a device is plugged in.
The step-down converter uses peak current mode control to regulate the output voltage (VOUT). Under light-load conditions, it enters pulse-frequency modulation (PFM) mode to achieve high light-load efficiency. Full protection features include hiccup current limiting, output over-voltage protection (OVP), and thermal shutdown. The device supports load-shedding mode for the USB1 port. When entering load-shedding, the Type-C advertised current capability changes to 1.5A.
The MPQ4253A-AEC1 requires a minimal number of readily available, standard external components, and is available in a QFN-26 (5mmx5mm) package.
- All-In-One USB Type-C + USB Type-A Solution
- USB Type-C Automatically Enters 1.5A Load Capability when the USB Type-A Port Detects a Device Is Plugged In
- Default Frequency Spread Spectrum Based on 480kHz (FREQ = Float)
- Auto-PFM/PWM Operation
- Wide 6V to 36V Operating Input Voltage (VIN) Range
- Selectable Output Voltage (VOUT): 5.1V, 5.17V, or 5.3V
- 90mV Line Drop Compensation
- Accurate USB1/USB2 Output Current (IOUT) Limit
- 18mΩ/15mΩ Low Internal RDS(ON) Buck Power MOSFETs
- 18mΩ/18mΩ Low Internal RDS(ON) USB1/USB2 Power MOSFETs
- 250kHz to 1MHz Adjustable Frequency
- Hiccup Current Limit for Both Buck and USB
- Supports DCP Schemes for BC1.2, Apple Divider 3 Mode, and 1.2V/1.2V Mode
- Supports USB Type-C 5V @ 3A DFP Mode
- Available in a QFN-26 (5mmx5mm) Package
MPQ4253AGU-AEC1-Z MPQ4253AGU-AEC1-P
MPQ4253A-AEC1 Resources
USB CHARGING PORTPRODUCT CATEGORY -
MPQ4241-AEC1PRODUCT65W, Fully Integrated USB PD Solution with 36V Tolerant Input Buck and PD3.1 DFP Controller, AEC-Q100 Qualified
MPF52001-AEC2PRODUCTSingle USB PD Controller for Source Port, Supporting Firmware Update and Advanced PDP Management, AEC-Q100 Qualified
MPQ4253B-AEC1PRODUCT36V Buck Converter Supports One USB Type-A, One USB Type-C Dual USB Charging Ports and Passes Apple MFI, AEC-Q100 Qualified
MPQ4242B-AEC1PRODUCT5A, 36V, Fully Integrated USB PD Solution with Integrated Buck-Boost Converter, AEC-Q100 Qualified
MPF52000-AEC2PRODUCTDual USB PD Controller for Source Ports, Supporting for Firmware Updates and Advanced PDP Management, AEC-Q100 Qualified
MPQ5029-C-AEC1PRODUCTUSB Charging Port Controller with Current-Limit Switch, Supporting CDP, DCP, and QC3.0 Modes, AEC-Q100 Qualified
MPQ5029-AEC1PRODUCTUSB Charging Port Controller with Integrated Current-Limit Switch and Short-to-Battery Protection for Automotive, AEC-Q100 Qualified
MPQ4276A-AEC1PRODUCT36V, 6A, Configurable-Frequency Buck Converter with Dual USB Charging Ports and PFM Mode under Light Loads, AEC-Q100 Qualified
MPQ4488B-AEC1PRODUCT36V, 6A, Step-Down Converter with Configurable Frequency Spread Spectrum and Dual USB Charging Ports, AEC-Q100 Qualified
MPQ4487A-AEC1PRODUCT36V, Buck Converter with Configurable-Frequency and Dual USB Charging Ports Supporting EN and Fault Indication for Automotive Applications, AEC-Q100 Qualified
MPQ4228-C-AEC1PRODUCT36V, 3A, Step-Down Converter with USB Charging Port Supporting CDP and Type-C 5V @ 3A DFP Mode, AEC-Q100 Qualified
MPQ4228-AEC1PRODUCT3A, 36V, Buck Converter with USB Charging Port Supporting DCP and Type-C 5V @ 3A DFP Mode, AEC-Q100 Qualified
MPQ4228-Q-AEC1PRODUCT3A, 36V, Step-Down Converter with 1-Channel USB Charging Port Supporting QC3.0 and Type-C 5V @ 3A DFP, AEC-Q100 Qualified
MPQ4475-E-AEC1PRODUCT36V, 2.5A, Frequency Selectable, Step-Down Converter with Single USB Charging Port AEC-Q100 Qualified
MPQ4485-AEC1PRODUCT36V, 6A, Step-Down Converter with Dual USB Charging Ports Supporting Type-C 5V @ 3A DFP Mode and BC1.2 CDP Mode for Automotive, AEC-Q100 Qualified
MPQ4210PRODUCT40V, 100W Synchronous Buck-Boost Controller with I2C and Current Monitor, AEC-Q100 Qualified
MPQ4229-C-AEC1PRODUCT3A, 36V, Step-Down Converter with USB Charging Port Supporting Up to 1.5V Line Drop Compensation, CDP, and USB Type-C 5V at 3A DFP Mode, AEC-Q100 Qualified
MPF52003-AEC2PRODUCTTriple-Port USB PD Controller for Source Ports Supporting Firmware Update and Advanced PDP Management for Automotive
INTRODUCING A FULLY INTEGRATED AUTOMOTIVE USB TYPE-A AND USB TYPE-C CHARGER CONTROLLERARTICLEThe car’s central control system has a USB charging port that must be able to charge mobile devices while transmitting data. For these systems, it is vital to select an automotive-grade IC with a USB current-limit switch. The article will introduce the MPQ4228-C-AEC1 and how its high efficiency can be utilized in USB hubs and other USB Type-C applications, as well as USB Type-A applications. Th...
MPQ4280-AEC1PRODUCTFully Integrated, Full-Bridge Buck Converter and OPAMP for Automotive Wireless Charging Transmitters, AEC-Q100 Qualified
POWER SUPPLY DESIGN FOR CAR INFOTAINMENT SYSTEMS (PART II)ARTICLEThis article is the second part of a two-part series covering power supply design for car infotainment systems. Part I discussed the performance requirements for primary and secondary power supplies in car infotainment systems. Part II addresses challenges regarding camera power supplies and USB charging in car infotainment systems. Figure 1 shows the car machine’s power architecture, including t...
POWER SUPPLY DESIGN FOR CAR INFOTAINMENT SYSTEMS (PART I)ARTICLEA car’s infotainment system is an on-board, integrated information processing system based on the car’s bus body and internet. Vehicles have become more integrated and modular as consumers continue to raise expectations for driving, car information resources, entertainment, and safety. This trend has introduced new challenges to the research and development of car infotainment systems, particularl...
USB TYPE-C BOOST AND BUCK-BOOST SOLUTIONS FOR PPSARTICLEGenerating USB Type-C (also called USB-C) charging power for multiple peripherals requires a flexible DC/DC converter that can work with a controller to deliver the desired voltage and current capability to the corresponding device. As power density increases — particularly in multiple-power port or hub applications — efficiency becomes paramount, and requires the lowest power loss to ...
MPQ5031-AEC1PRODUCTSingle-Port USB PD Controller for Source Only, AEC-Q100 Qualified
Order
