- MPC11057-54-0750-0100
Description
The MPC11057-54-0750-0100 is a high-efficiency, non-isolated LLC-DCX power card with a fixed 10:1 ratio. It operates from a 40V to 60V DC primary bus voltage, and can deliver a 4V to 6V output voltage (VOUT) and up to 750W of continuous power at a typical 54V input voltage (VIN).
The built-in multiple-time programmable (MTP) memory can store and restore device configurations. The fault status, VIN, VOUT, current, and temperature can be easily monitored via the communication interface. The MPC11057-54-0750-0100 is available in a surface-mount (53mmx18mmx6.8mm) package.
- Supports Up to 139A Continuous Load Current
- PMBus/I2C Interface
- Built-In Non-Volatile Memory (NVM) to Store Custom Configurations
- Input Voltage (VIN), Output Voltage (VOUT), Output Current (IOUT), Output Power (POUT), and Temperature Monitoring
- VIN Under-Voltage Lockout (UVLO), Output Over-Voltage Protection (OVP) and Under-Voltage Protection (UVP), Over-Current OCP_TDC/OCP_SPIKE Protections, and Over-Temperature Protection (OTP)
- Available in a Surface-Mount (53mmx18mmx6.8mm) Package
MPC11057-54-0750-0100-Z
MPC11057-54-0750-0100 Resources
POWER SOLUTION FOR 5GAPPLICATION -
48V MODULESPRODUCT CATEGORY -
MPC42013PRODUCT1.6kW, Regulated Quarter-BrickDC/DC Power Module
MPC1100C-54-0002PRODUCTHigh-Efficiency, Non-Isolated, Fixed Ratio, 300W, Digital DC/DC Power Module
MPC12106-54-0750-0220PRODUCTHigh-Efficiency, Fixed 4:1 Ratio, 800W Digital DC/DC Power Module
MP2421PRODUCT24V, 20A, Synchronous Step-Down Converter
MP29540PRODUCTDigital, Multi-Phase Controller
MP29816-CPRODUCTDual-Loop, Digital, 16-Phase Controller with PMBus and AVSBus Interface
MP5088PRODUCT5.5V, 15A, Low 2mΩ RDS(ON) E-Fuse with Inrush Current Control and Current Monitoring
MP2869APRODUCTDual-Loop, Digital, 16-Phase Controller with SVI3 Interface for AMD
MEETING THE IMPEDANCE MASK: STRATEGIES FOR PDN DESIGN AND OPTIMIZATIONARTICLEIn telecommunication applications, target impedance serves as a crucial benchmark for PDN design. It ensures that the die operates within an acceptable level of rail voltage noise, even under the worst-case transient current scenarios, by defining the maximum allowable PDN impedance for the power rail on the die. This article will focus on the optimization techniques to meet the target impedance ...
MPQ8785PRODUCT16V, 40A, Scalable, Digital, Synchronous Step-Down Converter with PMBus
MP5046PRODUCT60V, 5A E-Fuse with Configurable Current Limit and Reverse Current Protection
MP5024PRODUCT16V, 20A, 2.8mΩ RDS(ON), Hot-Swap Intelli-Fuse Solution with PMBus Lite
MPQ8626PRODUCT16V, 6A, High Efficiency, Synchronous, Step-Down Converter with Adjustable Current Limit
MPQ8633BPRODUCT16V, 20A, Synchronous, Step-Down Converter with Adjustable Current Limit, Configurable Frequency, and Voltage Tracking
MPQ8633APRODUCT16V, 12A, Synchronous Step-Down Converter with Adjustable Current Limit, Configurable Frequency, and Voltage Tracking
MPQ8643PRODUCT16V, 20A, Configurable-Frequency, Synchronous Step-Down Converter with Adjustable Current Limit and Voltage Tracking
MP8639PRODUCT16V, 6A, Fully Integrated, Low-IQ, Synchronous Step-Down Converter
