Linear Hall-Effect Current Sensor Use Case: Multi-Phase Inverters
This use case examines the application of the MCS1806 linear Hall-effect current sensor in multi-phase inverters.
The MCS1806 linear Hall-effect current sensor provides integrated current sensors combined with built-in phase synchronization, resulting in improved accuracy and power quality for multi-phase inverters.
Multi-phase inverters are used in a variety of high-power applications, including renewable energy systems, electrical vehicles (EVs), and industrial drives, where DC power is converted to multi-phase AC power. Achieving accurate current sensing and precise phase control are two significant challenges in multi-phase inverter design. While shunt resistors and Hall-effect sensors are often implemented for current sensing, choosing between these techniques requires a difficult tradeoff between accuracy and power loss, in addition to managing overall susceptibility to interference and noise with both techniques.
The MCS1806 linear Hall-effect current sensor provides integrated current sensors combined with built-in phase synchronization, resulting in improved accuracy and power quality for multi-phase inverters. Accurate current sensing can be maintained even in high-noise environments due to the MCS1806’s differential Hall array, which cancels out any stray magnetic field. The small SOIC-8 footprint saves board area and makes it well-suited for space-constrained applications.
Additional features include:
- 3.3V or 5V Single-Supply Options
- Immune to External Magnetic Fields via Differential Sensing
- 3kVRMS Minimum Isolation Voltage
- 500VRMS Maximum Working Voltage
- ±2.5% Total Error
- 0.9mΩ Internal Conductor Resistance
- ±5A to ±50A Bidirectional Range
- Adjustable Bandwidth Up to 100kHz
- Ratiometric Output from Supply Voltage
- Output Proportional to the AC or DC Currents
- Factory-Trimmed for Accuracy
- No Magnetic Hysteresis
Learn more about MPS’s excellent selection of current sensors for AC or DC current sensing.
Related Content
VIDEO
Smallest Isolated Linear Hall-Effect Current Sensor: MCS1806
This linear, Hall-effect current sensor delivers 3kVRMS minimum isolation voltage and 500VRMS maximum working voltage.
DC Fast Charging System: Maximizing Power Density with an LLC Transformer Driver
As the world strives for carbon neutrality, electric vehicles (EVs) are rapidly taking market share from internal combustion engine vehicles.
Three-Phase Inverters
This article discusses numerous three-phase inverter types, their essential parts, and circuit topologies.
Renewable Energy Systems
Power electronics are essential in integrating renewable energy sources, particularly solar and wind energy systems, into the power grid or independent systems.
