The EVQ4487-U-00A is an evaluation board for MPQ4487, which integrates a monolithic step-down switch-mode converter with two USB current-limit switches and Type-C 5V@3A mode configure channel for each port. It achieves 6A max output current over a wide input-supply range with excellent load and line regulation.
The output of the USB switch is current limited. Both USB ports support TYPE-C 5V@3A DFP Mode eliminating outside user interaction.
Fault condition protection includes hiccup current limiting, output OVP, and thermal shutdown (TSD).
Show moreShow less
Forgot Password
Log in to continue
myMPS+
