The EV8760D-L-00A is an evaluation board for the MP8760DGL, a high-efficiency, monolithic, synchronous, step-down converter with output discharge function.
The evaluation board can deliver a continuous 6A load current over an 8V to 18V operating input range. The evaluation board can achieve high efficiency over a wide output current load range. Constant-on-time (COT) control provides fast transient response and eases loop stabilization.
This evaluation board can be turned on or shut down via a remote on/off input that is referenced to ground. This input is compatible with popular logic devices.
Show moreShow less
Forgot Password
Log in to continue
myMPS+
