EV7742DF-00B
Active
2x15W Stereo Class-D Single Ended Audio Amplifier EV Board
    $50.00 /unit
Arrives 3-4 business days.
Shipping only $5 per order.
The EV7742DF-00B is the evaluation board for the MP7742, a stereo 15W Class D Audio Amplifier. It is one of MPS’ products of fully integrated audio amplifiers which dramatically reduces solution size by integrating the following:
  • 250mΩ power MOSFETs
  • Startup / Shutdown pop elimination
  • Short circuit protection circuits
The MP7742 utilizes a single ended output structure capable of delivering 2x15W into 4Ω speakers. MPS Class D Audio Amplifiers exhibit the high fidelity of a Class A/B amplifier at high efficiency. The circuit is based on the MPS’ AAMTM proprietary variable frequency topology that delivers excellent linearity, fast response time and operates on a single power supply.
  • 15W Output at VDD = 24V into a 4Ω load
  • THD+N = 0.018% at 1W, 8Ω, 1kHz
  • 90% Efficiency at 15W and VDD=24V with 4Ω load
  • Low Noise (103μV Typical)
  • 9.5V to 28V Operation from a Single Supply
30W Class-D Mono BTL Audio Amplifier
The MP7742 is a Stereo 2 x 15W Class-D Audio Amplifier. It is one of MPS' products of fully integrated audio amplifiers which dramatically reduces solution size by integrating the following: •250mΩ power MOSFETs,• Startup / Shutdown pop elimination,• and short circuit protection circuits. The MP7742 utilizes a single ended output structure capable of delivering 15W per channel into 4Ω speakers. MPS Class D Audio Amplifiers exhibit the high fidelity of a Class A/B amplifier at high efficiencies. The circuit is based on the MPS' proprietary variable frequency topology that delivers excellent linearity, fast response time and operates on a single power supply.
