EV3352DQ-00A
Active
Integrated Photo Flash Charger IGBT Driver EV Board
    $75.00 /unit
Arrives 3-4 business days.
Shipping only $5 per order.
The EV3352DQ-00A is an evaluation board for the MP3352, a fast, highly efficient and precision high voltage photo-flash charger for xenon flash applications.
The programmable peak current is up to 2.5A to ensure fast charging time.  200mΩ internal power switch minimizes the conduction loss. 55V maximum SW operating voltage lowers transformer turns ratio and switching loss associated with the primary leakage inductance.
The board offers charge-ready indicator, quench function, flash mode, red-eye reduction + flash mode.
  • Programmable Peak Current Up to 2.5A
  • 3% Charge Accuracy
  • Quench Function
  • Charge-ready Indicator
  • Microcontroller Controlled On/Off, Flash or Red Eye Reduction + Flash Mode
  • Integrated IGBT Driver
  • IC Supported 1MP3352
60V, 2.5A Integrated Photo Flash Charger with IGBT Driver and Quence
The MP3352 is a fast, highly efficient, precision high-voltage photo-flash charger with integrated IGBT driver for xenon flash applications. The programmable peak current is up to 2.5A to ensure fast charging time. A 200mΩ internal power switch minimizes the conduction loss. In addition, a 60V maximum voltage lowers the transformer turns ratio and improves the switching loss associated with the primary leakage inductance. External feedback provides 3% charge accuracy.
The MP3352 is available in a 16-pin 3mm x 3mm QFN package.
