EV2662-C-00A
New
Evaluation Board of 500mA Linear Charger with Power Path Management, 1mA Termination and <1μA Battery Leakage for Single-Cell Li-Ion Battery
    $49.00 /unit
The EV2662-C-00A is an evaluation board for the MP2662, a highly-integrated single-cell Li-Ion/Li-Polymer battery charger with system power path management, targeted at space limited portable applications. It takes input power from either an AC adapter or a USB port to supply the system load and charge the battery independently. The charger section features constant current pre charge (PRE.C), constant current fast charge (CC) and constant voltage (CV) regulation, charge termination and charge status.
EV2662 ensures the continuous power to the system by automatically selecting the input, the battery or both to power the system.
EV2662 provides system short circuit protection to prevent the Li-Ion battery from being damaged due to excessive high current.
EV2662 cuts off the path between battery and system when battery UVLO to prevent the Li-Ion battery from being overly discharged.
Through the I2C connector on EV2662, the customer can program the charging parameters, such as: input current limit, input minimum voltage regulation, charging current, battery regulation voltage, and battery UVLO.
  • Fully Autonomous Charger for Single-Cell Li‑Ion/Polymer Batteries
  • Current Limit forUSBPort
  • Complete Power Path Management for Simultaneously Powering the System and Charging theBattery
  • 0.5% Charging Voltage Accuracy
  • 21V Maximum Voltage for the Input Source
  • I2C Interface for Setting charging Parameters and Status Reporting
  • Robust Charging Protection Including Battery Temperature Monitor and Programmable Timer
  • BatteryDisconnection Function
500mA Single-Cell Li-ion Battery Charger with Power Path Management, 1mA Termination and <1μA Battery Leakage
The MP2662 is a highly integrated, single-cell, Li-ion/Li-polymer battery charger with system power path management for space-limited portable applications. The MP2662 takes input power from either an AC adapter or a USB port to supply the system load and charge the battery simultaneously. The charger function features pre-charge (PRE.C), fast current (CC) and constant voltage (CV) regulation, charge termination, and auto-recharge.
The power path management function ensures continuous power to the system by automatically selecting the input, battery, or both to power the system. This function features a low dropout regulator from the input to the system and a 100mΩ switch from the battery to the system. Power path management separates the charging current from the system load, which allows for proper charge termination and keeps the battery in full-charge mode.
The MP2662 provides a system short-circuit protection (SCP) function by limiting the current from the input to the system and the battery to the system. This feature is especially critical for preventing the Li-ion battery from being damaged due to an excessively high current. An on-chip battery under-voltage lockout (UVLO) cuts off the path between the battery and the system if the battery voltage drops below a programmable battery UVLO threshold. This prevents the Li-ion battery from being over-discharged. An integrated I2C control interface allows the MP2662 to program the charging parameters, such as input current limit, input minimum voltage regulation, charging current, battery regulation voltage, safety timer, and battery UVLO.
The MP2662 is available in a 9-pin WCSP (1.75mmx1.75mm) package.
Configure multiple charging parameters for the MP2662
By using this I2C GUI, you can configure multiple charging parameters for the MP2662.
System Requirements:
  • Operating System of Windows XP, 7 or later
  • Net Framework 4.0
  • PC with a minimum of one available USB port
  • At least 22.2 MB of free space
Communication Interface Device USB to I2C/PMBus, included with product evaluation kit or can be purchased separately.
The EVKT-USBI2C-02 is included with the product evaluation kit, or it can be purchased separately. This communication interface provides the USB to I2C port as well as PMBus capabilities. It is designed to work with MPS I2C and PMBus products, and Virtual Bench Pro, and I2C GUI tools.  Together with MPS Virtual Bench Pro and I2C GUI tools, it provides a quick and easy way to evaluate the performance of MPS digital products.
The EVKT-USBI2C-02 kit includes:
  • 1 USB to I2C communication device interface
  • 1 USB cable
  • 1 10-pin ribbon cable
  • 1 3-pin ribbon cable
  • Thumbdrive with datasheet and driver files
$25.00 + tax
$75.00 + tax
