- Products
- Automotive (AECQ Grade)
- System Supervision
- Power Sequencers
- MPQ79720FS-AEC1
MPQ79720FS-AEC1
- Number of Channels8
- Vin (min) (V)2.7
- Vin (max) (V)5.5
- 32kHz Crystal Oscillator DriverYes
- RTCYes
- System Reset SignalYes
- Watchdog TimerYes
- Package (mm)QFN-24 (4x4)
- GradeAutomotive
The MPQ79720FS-AEC1 is an 8-channel, functional safety power sequencer engineered to provide precise power sequencing and safety functions for automotive advanced driver-assistance systems (ADAS) and autonomous driving platforms.
The device’s configurability and flexibility enable design reuse across different applications and system-on-chip (SoC) generations.
The MPQ79720FS-AEC1 contains a crystal driver, a real-time clock (RTC) with an alarm function, a configurable watchdog that can be accessed through the I2C interface, and active-low system reset and interrupt outputs.
Safety mechanisms such as built-in self-testing (BIST) provide high diagnostic coverage, which helps the system achieve its target ASIL rating.
The MPQ79720FS-AEC1 is available in a QFN-24 (4mmx4mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- Designed for Automotive Advanced Driver Assistance Systems (ADAS) and Autonomous Driving Platforms:
- 8 Enable Outputs
- Time Slot Based Sequencing
- System Interrupt Signal
- Mission-Critical Safety Features:
- Write Protection on Safety Critical Registers
- Advanced Diagnostics
- Window Watchdog
- Over-Temperature Shutdown
- Support Systems Up to ASIL-D
- ISO 26262 Functional Safety Compliant
- Fast Mode I2C Interface with Cyclic Redundancy Check (CRC)
- Configurable Parameters:
- Sequence Order
- I2C Address
- Watchdog Timing
- Drive Mode for Enable Pins
- Alternate Functions for Enable Pins
- Additional Features:
- Backup Battery Input
- Real-Time Clock (RTC)
- Available in a QFN-24 (4mmx4mm) Package with a 0.5mm Pitch and Wettable Flanks
- Available in AEC-Q100 Grade 1:
- Developed for Functional Safety Applications: ISO 26262 Compliant
MPQ79720FSGRE-xxxx-AEC1-Z MPQ79720FSGRE-xxxx-AEC1-P MPQ79720FSGRE-0000-AEC1-Z MPQ79720FSGRE-0000-AEC1-P
MPQ79720FS-AEC1 Resources
POWER SEQUENCERSPRODUCT CATEGORY -
MPQ79731FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79730FS-AEC1PRODUCTMPSafeTM, ASIL-D, 6-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79721FS-AEC1PRODUCTMPSafeTM, ASIL-B, 8-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79711FS-AEC1PRODUCTMPSafeTM, ASIL-B, 10-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79710FS-AEC1PRODUCTMPSafeTM, ASIL-D, 10-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79701FS-AEC1PRODUCTMPSafeTM, ASIL-B, 12-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79700FS-AEC1PRODUCTMPSafeTM, ASIL-D, 12-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79571FS-AEC1PRODUCTMPSafeTM, ASIL-D, Wide 36V VIN, Window Voltage Supervisor, AEC-Q100 Qualified
MPQ72963FS-AEC1PRODUCTMPSafeTM, ASIL-D, 3-Rail, 9-Phase Controller with Digital Interface, AEC-Q100 Qualified
MPQ1966-AEC1PRODUCT100V, 4A, High-Frequency, Half-Bridge, N-Channel Power Gate Driver
MPQ86761-AEC1PRODUCT60A Intelli-PhaseTM Solution in a TQFN-21 (3.5mmx6mm) Package, AEC-Q100 Qualified
MPQ86725-AEC1PRODUCTIntelli-PhaseTM Solution in TQFN (3.5mmx4mm) Package, AEC-Q100 Qualified
MPQ86720-AEC1PRODUCT65V Intelli-PhaseTM Solution in a TQFN-22 (5mmx6mm) Package, AEC-Q100 Qualified
MPQ29252-AEC1PRODUCTDigital Multi-Phase Controller, AEC-Q100 Qualified
MPQ79531FS-AEC1PRODUCTMPSafeTM, ASIL-B, 3-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ29260-AEC1PRODUCT60V, Multi-Phase Step-Down Controller, AEC-Q100 Qualified
MPQ70156FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6V, 3A, PMIC with Buck Converter and 1-Channel Window Voltage Monitor, AEC-Q100 Qualified
