- MPQ58200-AEC1
MPQ58200-AEC1
Description
The MPQ58200-AEC1 is a 32-channel, high-side (HS) switch for VCSEL applications. It is designed to pre-charge the input capacitors of VCSEL diodes. By working with a proper low-side (LS) FET, the device provides a compact and flexible solution for LiDAR applications.
The device integrates an open-loop boost converter, and its duty cycle is controlled by an external pulse-width modulation (PWM) waveform. When the boost converter's LS FET is on, the inductor current increases; when the LS FET is off, the inductor current charges the output capacitor of one channel, which is selectable via the SEL pins. In this way, the energy delivered to each output can be adjusted by changing the width of the PWM signal. This process also helps to compensate for the inconsistency of the parasitic inductance related to the VCSEL diode's discharging loop. Therefore, the VCSEL diode distributes currents among various channels, allowing it to achieve the same pulse value.
The MPQ58200-AEC1 integrates thorough protection features to ensure that the device can protect itself and detect various fault conditions, including input over-voltage protection (OVP) and under-voltage lockout (UVLO), output OVP, and over-current protection (OCP) for the boost converter.
The MPQ58200-AEC1 is available in a WLCSP-45 (2.5mmx4.5mm) package.
- Extend Battery Life:
- 1μA Shutdown Quiescent Current
- 380μA Supply Quiescent Current
- Vast Flexibility:
- Integrated Boost Converter
- Configurable Output Voltage with Pulse-Width Modulation (PWM) Input
- Independent Output Channel Control
- Selectable Pre-Defined Sequence
- Full Protection and Diagnostics:
- Over-Current Protection (OCP) for Boost
- Input Over-Voltage Protection (OVP) and Under-Voltage Lockout (UVLO)
- Output OVP
- Output Discharge
- Report Fault with Hardware Pin
- Other Features:
- High-Side (HS) Charging FET
- Low-Side (LS) Discharging FET
- 3.3V/1.8V Microcontroller Unit (MCU) Compatible
- MPSafeTM Compatible - Functional Safety Supporting Document Available
MPQ58200GC-xxxx-AEC1-Z MPQ58200GC-xxxx-AEC1-P
MPQ58200-AEC1 Resources
SMART HIGH SIDE SWITCHPRODUCT CATEGORY -
MPQ5895-AEC1PRODUCT60V Load Dump, 3A, Dual-Channel, Smart High-Side Switch, AEC-Q100 Qualified
POWERING THE AUTOMOTIVE REVOLUTION: FROM ZONAL ARCHITECTURE TO 48VARTICLEThe automotive industry is in the midst of a massive transformation. Over the past decade, cars are increasingly being equipped with advanced features that provide customers with greater safety, comfort, ease of use, and enjoyment. That includes everything from heated seats to infotainment screens, safety cameras to high-end sound systems. Some of the most innovative vehicles are fully self-drivin...
MPQ5870L-AEC1PRODUCT28V, 0.5A, Single-Channel, Smart High-Side Load Switch with High-Accuracy Current Sense, AEC-Q100 Grade 1 Qualified
MPQ5862C-AEC1PRODUCT16V, 1.5A, Dual-Channel, High-Side Switch, AEC-Q100 Qualified
MPQ5892-AEC1PRODUCT36V, 5A, Dual-Channel, Smart High-Side Switch, AEC-Q100 Qualified
MPQ5870-AEC1PRODUCT60V, 0.5A, Single-Channel, Smart High-Side Load Switch with High-Accuracy Current Sense, AEC-Q100 Qualified
MPQ5893-AEC1PRODUCT60V Load Dump, 5A, Dual-Channel, Smart High-Side Switch, AEC-Q100 Qualified
MPQ5882-AEC1PRODUCT80V, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
MPQ5887-AEC1PRODUCT80V, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
MPQ5889-AEC1PRODUCT80V, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
MPQ5856-AEC1PRODUCT42V, Smart High-Side Driver IC, AEC-Q100 Qualified
MPQ5073N-AEC1PRODUCT5.5V, 2A, Load Switch, AEC-Q100 Qualified
MPQ5071N-AEC1PRODUCT5.5V, 1A Load Switch, AEC-Q100 Qualified
MPQ77240FS-AEC1PRODUCTMPSafeTM, ASIL-B/D, 16V, 180mΩ, 0.8A, Quad-Channel, High-Side Switch, AEC-Q100 Qualified
MPQ5884-AEC1PRODUCT80V, 4.5mΩ, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
VIDEO
QUAD-CHANNEL HIGH-SIDE SWITCH FOR AUTOMOTIVE: MPQ77240FS-AEC1VIDEOThe MPQ77240FS-AEC1 is a scalable, flexible, quad-channel high-side switch engineered for the most demanding automotive applications. Supporting a 5V to 16V input voltage range and up to 0.8A of load per channel, it ensures system safety with features like short-to-battery protection, over-current protection (OCP), and thermal shutdown. The MPQ77240FS-AEC1 delivers compact, space-saving power cont...
MPQ5862-AEC1PRODUCT16V, 1.5A, 90mΩ RDS(ON), Dual-Channel, High-Side Switch, AEC-Q100 Qualified
