- MPQ3322-AEC1
MPQ3322-AEC1
24-Channel, Max 100mA/Channel, Current-Source LED Driver with Independent PWM and Analog Dimming, AEC-Q100 Qualified
- Vin (min) (V)3.5
- Vin (max) (V)22
- Channels24
- Ichannel (max) (A)0.1
- LEDx ABS Voltage (V)24
- TopologyLED Driver with Current Source
- Dimming (Output)P-Dim, A-Dim
- Iq (mA)8
- Ishutdown (µA)2
- GradeAutomotive
- Package (mm)QFN-40 (6x6)
- Power MOSFETIntegrated
- Typical LCD Screen SizesSmall (<10"), Medium (10" to 17"), Medium (10" to 29")
The MPQ3322-AEC1 is a 24-channel LED driver with a 24V voltage rating and maximum 100mA current sources. It is designed to drive LED arrays for backlighting, RGB lighting, and interior ambient lighting in automotive LCD panels and lamps.
The MPQ3322-AEC1 employs low headroom to regulate the LED current (ILEDx, where x = 1 to 24). The adaptive voltage feedback (AVF) for the previous power stage optimizes the output voltage (VOUT) for LED strings, which achieves higher system efficiency.
The device supports independent 12-bit pulse-width modulation (PWM) and 6-bit analog dimming for each channel via the based-controller area network (CAN) differential interface. The resistor on the ISET pin (RISET) configures the maximum ILEDx amplitude.
Robust protections are included to guarantee safe device operation. Protection modes include LED open protection, LED short protection (with a configurable threshold via the STH bits (04h, bits[1:0]), and over-temperature protection (OTP). All fault statuses can be read through the CAN interface. In addition, the failsafe function ensures that the MPQ3322-AEC1 remains operating in a preset state if communication information is lost.
The FF pin and single lamp mode (SLM) support single-IC and multi-IC applications for two fault statuses. If one channel fails, then the IC either only turns off the failed LED string or shuts down all channels.
The MPQ3322-AEC1 is available in a QFN-40 (6mmx6mm) package with wettable flanks, and is available in AEC-Q100 Grade 0.
- 3.5V to 22V Input Voltage (VIN) Range
- 24 Channels with Max 100mA per Channel
- <2.5% Current Matching
- Low Dropout Voltage (500mV at 100mA)
- Independent 12-Bit Pulse-Width Modulation (PWM) Dimming
- Independent 6-Bit Analog Dimming
- Adaptive Voltage Feedback (AVF) Function
- 2MHz Based Controller Area Network (CAN) Differential Interface
- Cascades Up to 16 ICs (Pin-Configurable Device Address)
- Improves EMI with LED Current (ILEDx, Where x = 1 to 24) with Slew Rate and Phase Shift
- LED Open/Short Protection
- Fault Indicator Signal Output
- Configurable FF Mode: Fault Flag Mode (FFM) and Single Lamp Mode (SLM)
- Failsafe for Loss of Communication
- Failsafe Mode Set Function
- Available in a QFN-40 (6mmx6mm) Package with Wettable Flanks
- Available in AEC-Q100 Grade 0
MPQ3322GQKE-xxxx-AEC1-Z MPQ3322GQKE-xxxx-AEC1-P MPQ3322GQKE-0000-AEC1-Z MPQ3322GQKE-0000-AEC1-P
MPQ3322-AEC1 Resources
RGB LED DRIVERSPRODUCT CATEGORY -
BACKLIGHT DRIVERS (WLED)PRODUCT CATEGORY -
MPQ3368-AEC1PRODUCT8-Channel, Max 200mA/Channel, Boost WLED Controller with 10000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3321A-AEC1PRODUCT48-Channel, Max 80mA/Channel, Current-Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ3365-AEC1PRODUCT4-Channel, Max. 150mA/Ch, Boost WLED Driver with 15000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3365A-AEC1PRODUCT5-Channel, Max 150mA/Ch, Boost WLED Driver with 15000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3366C-AEC1PRODUCT6-Channel, Max 200mA/Channel, Boost WLED Controller with 10000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3359C-AEC1PRODUCT1/2/3/4-Channel, Max 160mA/Ch, Boost WLED Controller with High Dimming Ratio, AEC-Q100 Qualified
MPQ3621-AEC1PRODUCT48-Channel, Max 50mA/Ch, Current Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ3321-AEC1PRODUCT48-Channel, Max 80mA/Ch, Current Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ3359A-AEC1PRODUCT1-/2-/3-/4-Channel, Max 150mA/Ch Boost WLED Driver with High Dimming Ratio, AEC-Q100 Qualified
MPQ3327-AEC1PRODUCT4-Switching Line Scan Driver with Serial Interface and GPIO Control
MPQ3359-AEC1PRODUCT4-Channel, Max 150mA/Channel, Boost WLED Driver with High Dimming Ratio, AEC-Q100 Qualified
MP3320NPRODUCT3-Channel, Charge Pump RGB LED Driver
MP3320BPRODUCT4-Channel, Synchronous Boost RGBW LED Driver with Digital Interface
MP3326APRODUCT16-Channel, 80mA/Channel, LED Driver with Separate PWM/Analog Dimming and Digital Interface
MP3320APRODUCT4-Channel, Charge Pump RGB LED Driver with Digital Interface
MPQ3323B-AEC1PRODUCT4-Channel, 320mA/Ch, LED Driver with Separated PWM/Analog Dimming and Digital Interface, AEC-Q100 Qualified
MPQ3326B-AEC1PRODUCT16-Channel, 80mA/Ch, LED Driver with Separated PWM/Analog Dimming and Serial Interface (Default Enable), AEC-Q100 Qualified
MPQ3326A-AEC1PRODUCT16-Channel, 80mA/Ch, LED Driver with Separated PWM/Analog Dimming and Serial Interface, AEC-Q100 Qualified
MP3324PRODUCT8-Channel, 100mA/Ch, LED Driver with Separated PWM/Analog Dimming and I2C Interface
MPQ3367A-AEC1PRODUCTLow-EMI, 6-Channel, Max 150mA/Ch, Boost WLED Driver with 15000:1 Dimming Ratio and I2C Interface, AEC-Q100 Qualified
MP3326PRODUCT16-Channel,50mA/Ch,LEDDriver withSeparate PWMAnalog DimmingandI2CInterface
Order
