MPQ2295-AEC1
- Vin (min) (V)2.7
- Vin (max) (V)6
- Iout (max) (A)30
- Iq (typ) (mA)2
- fsw (max) (kHz)4000
- Control ModeZero-Delay PWM
- Package (mm)TLGA-25 (3x4.5)
- GradeAutomotive
The MPQ2295-AEC1 is a configurable, high-frequency, synchronous buck converter with integrated internal high-side and low-side power MOSFETs (HS-FET and LS-FET, respectively). The device operates from a 2.7V to 6V input and provides 30A of highly efficient output current (IOUT) with fixed-frequency, zero-delay pulse-width modulation PWM (ZDPTM) control for fast transient response.
The configurable 2MHz to 4MHz switching frequency (fSW) during forced continuous conduction mode (FCCM) greatly reduces the external inductance and capacitance. Internal feedback and compensation minimize external component count and improve accuracy. High power conversion efficiency across a wide load range is achieved by skipping pulses under light-load conditions to reduce the fSW and gate driving losses.
Full protection features include short-circuit protection (SCP), over-current protection (OCP), input over-voltage protection (OVP), output OVP, and thermal shutdown, which provide reliable, fault-tolerant operation.
The device integrates an I2C digital interface with packet error checking (PEC) and integrated multi-page one-time programmable (OTP) memory, allowing for user configurations with a high degree of configurability.
The MPQ2295-AEC1 is available in a TLGA-25 (3mmx4.5mm) package, and it is available in AEC-Q100 Grade 1.
- Designed for Automotive Point-of-Load (PoL) Applications:
- 2.7V to 6V Input Voltage (VIN)
- 30A Continuous Output Current (IOUT)
- 1.0% Output Regulation Accuracy
- Differential Output Voltage (VOUT) Sense
- Internal High-Side and Low-Side MOSFETs (HS-FET and LS-FET, Respectively)
- Optimized for EMC/EMI:
- Constant Frequency Pulse-Width Modulation (PWM) with Spread Spectrum
- Configurable 2MHz, 2.2MHz, 3MHz and 4MHz Switching Frequency (fSW)
- Input for Frequency and Phase Synchronization
- Flexible Application with I2C Digital Interface
- Digital Interface with Cyclic Redundancy Check (CRC):
- Converter On/Off
- VOUT Setting Range from 0.20625V to 3.6V
- Faults Detection
- Factory Configurable One-Time Programmable (OTP) Memory
- Additional Features:
- Soft Start and Soft Stop
- Power Good
- Redundant Bandgap, Clock, and VCC
- Short-Circuit Protection (SCP), Over-Current Protection (OCP), and Over-Voltage Protection (OVP)
- Thermal Warning and Thermal Shutdown
- Protected Memory and Registers
- VOUTP and VOUTN Open Detection
- Available in a TLGA-25 (3mmx4.5mm) Package
- MPSafe™ Compatible – Functional Safety Supporting Document Available
MPQ2295GLYT-xxxx-AEC1-Z MPQ2295GLYT-xxxx-AEC1-P MPQ2295GLYT-0000-AEC1-Z MPQ2295GLYT-0000-AEC1-P
MPQ2295-AEC1 Resources
MPQ71017FS-AEC1PRODUCTMPSafeTM, ASIL-D, 6V, 15A, Synchronous Buck Converter with ZDPTM, AEC-Q100 Qualified
MPQ2176A-AEC1PRODUCT5.5V, 4A to 6A, 2.2MHz, Synchronous Step-Down Converter in a TLGA-13 Package, AEC-Q100 Qualified
MPQ71019FS-AEC1PRODUCTMPSafeTM ASIL-D, 6V, 25A, Synchronous Buck Converter with ZDPTM, AEC-Q100 Qualified
