- MPQ20088-AEC1
MPQ20088-AEC1
40V, 500mA, High-Precision, High PSRR, Adjustable Output Linear Regulator, AEC-Q100 Qualified
Description
The MPQ20088-AEC1 is a low-power, low-dropout (LDO) linear regulator that supplies power to systems that are connected to the battery in automotive applications. It includes a wide 3V to 40V input voltage (VIN) range, making it capable of withstanding transients such as load dump that are anticipated in automotive systems.
With a 45µA quiescent current (IQ), the MPQ20088-AEC1 is an optimal solution for powering always-on components such as microcontrollers and controller area network transceivers in standby systems. The wide output voltage (VOUT) range allows the device to generate the bias voltage for silicon carbide (SiC) gate drivers and microphones, as well as power microcontroller units (MCUs) and processors.
The MPQ20088-AEC1 also incorporates exceptionally precise VOUT accuracy of ±1.5% across line, load, and temperature. This allows the device to quickly react to changes in load or line, such as during cold-crank conditions.
The MPQ20088-AEC1 is available in SOT-89 and TO-252-3 packages, and is available in AEC-Q100 Grade 1. The low thermal resistance enables sustained operation against dissipation across the device.
- Versatile Voltage Range:
- Wide Input Voltage (VIN) Range: 3V to 40V (42V Max)
- Fixed Output (3.3V, 5V)
- Reduced Board Size
- TO-252 Package: 10.3mmx6.7mm
- SOT-89 Package: 4.6mmx4.25mm
- Additional Features:
- Output ±1.5% Accuracy Over Temperature
- 60 dB PSRR @1 kHz
- Specified Current Limit
- Power Good (PG) with Configurable Delay
- Thermal Shutdown and Short-Circuit Protection (SCP)
- MPSafeTM Compatible - Functional Safety Supporting Document Available
MPQ20088GZD-xxxx-AEC1-Z MPQ20088GZD-xxxx-AEC1-P MPQ20088GZN-xxxx-AEC1-Z MPQ20088GZN-xxxx-AEC1-P
MPQ20088-AEC1 Resources
LDOPRODUCT CATEGORY -
MPQ20082-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ2019A-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Linear Regulator with Adjustable Output, AEC-Q100 Qualified
MPQ2013D-AEC1PRODUCT40V, 100mA, Low Quiescent Current Linear Regulator, AEC-Q100 Qualified
MPQ2024A-AEC1PRODUCT40V, 300mA, Phantom Antenna LDO with Pre-Boost, Digital Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2026A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Pre-Boost, Industry-Standard Synchronous Serial Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2022A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Serial Digital Interface and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2016-AEC1PRODUCT40V, 30mA, Low IQ Linear Regulator, AEC-Q100 Qualified
MPQ20073-AEC1PRODUCT2A, 1.3V to 6V DDR Memory Termination Regulator AEC-Q100 Qualified
MPQ2019-AEC1PRODUCT40V, 300mA, Low-Quiescent Current Adjustable Output Linear Regulator
MPQ2013-AEC1PRODUCT40V, 150mA, Low Quiescent Current Linear Regulator
MPQ2029-AEC1PRODUCT40V, 450mA, Low-Quiescent Current Adjustable Output Linear Regulator, AEC-Q100
MPQ20051-AEC1PRODUCTLow Noise, High PSRR, 1A Linear Regulator with AEC-Q100 qualified
MPQ8904-AEC1PRODUCTAutomotive Grade 500mA Linear Regulator
