Automotive Grade, 1.5A, 36V, Synchronous Step-Down Power Module with Integrated Inductor and Power Good,
The MPM3515-AEC1 is a synchronous, rectified, step-down converter with built-in power MOSFETs, inductors, and capacitors. The MPM3515-AEC1 offers a very compact solution and requires only four external components to achieve 1.5A of continuous output current with excellent load and line regulation over a wide input supply range. The MPM3515-AEC1 operates with a 2.2MHz switching frequency to achieve a fast load transient response. Full protection features include over-current protection (OCP) and thermal shutdown. The MPM3515-AEC1 eliminates design and manufacturing risks while improving the time to market dramatically. The MPM3515-AEC1 is available in a space-saving QFN-17 (3mmx5mmx1.6mm) package.
  • Complete Switch-Mode Power Supply
  • Wide 4V to 36V Operating Input Range
  • 1.5A Continuous Load Current
  • 90mO/50mO Low RDS(ON) Internal Power MOSFETs
  • Fixed 2.2MHz Switching Frequency
  • Frequency Foldback at a High Input Voltage
  • 450kHz to 2.2MHz Frequency Sync
  • Forced Continuous Conduction Mode (CCM )
  • Power Good (PG) Indicator
  • Over-Current Protection (OCP) with Valley-Current Detection and Hiccup
  • Thermal Shutdown
  • Output Adjustable from 0.8V
  • Available in a QFN-17 (3mmx5mmx1.6mm) Package
  • CISPR25 Class 5 Compliant
  • Available in a Wettable Flank Package
  • fsw (max) (kHz)2200
  • Vin (min) (V)4
  • Vin (max) (V)36
  • Iout (max) (A)1.5
  • Isw Limit (typ) (A)4
  • Max Duty Cycle (%)0.85
  • Vfb (typ) (V)0.807
  • Iq (typ) (mA)0.6
  • Regulated Outputs1
  • Vout (max) (V)30
  • Vout (min) (V)0.8
  • mps_Status2
  • GradeAutomotive
  • PackageQFN-17 (3x5x1.6)
  • Special Features450kHz to 2.2MHz Frequency Sync, Forced CCM, Frequency Foldback at High Input Voltage, OCP with Hiccup Mode
  • SSInternal
  • PGYes
