- Products
- Power Modules
- Intelli-Module
- MPC24180-260
MPC24180-260
- Module AssemblyOpen Frame
- Vin (min) (V)4
- Vin (max) (V)16
- Vout (min) (V)0.5
- Vout (max) (V)2
- Iout (max) (A)260
- fsw (min) (kHz)500
- fsw (max) (kHz)1500
- Dimension WxL (mm)9x10
- Dimension (H) (mm)4.8
- Mounting TypeSurface Mount
- GradeIndustrial
- Dimension (H) (Max) (mm)5
The MPC24180-260 is a four-phase, non-isolated, high-efficiency step-down Intelli-ModuleTM. It integrates the driver MOSFETs (DrMOS), inductors, and output capacitors to provide high efficiency and a small footprint, which is ideal for server applications.
The device can achieve up to 260A (65A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC24180-260 offers many features to simplify system design. It works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current-sensing to monitor the inductor current (IL), and has temperature-sensing to report the junction temperature (TJ).
The MPC24180-260 is available in an LGA-54 (9mmx10mmx4.8mm) package.
- Up to 260A of Continuous Output Current (IOUTx)
- Temperature Sense
- Fault Reporting
- Typical Weight: 1.75g
- Available in an LGA-54 (9mmx10mmx4.8mm) Package
MPC24180-260-T
MPC24180-260 Resources
ARTIFICIAL INTELLIGENCE (AI) SOLUTIONAPPLICATION -
MPC22174-170PRODUCTDual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
USE CASE
