- MPC22157-A-130
MPC22157-A-130
Description
The MPC22157-A-130 is a dual-phase, non-isolated, high-efficiency step-down power module. It integrates the driver MOSFETs (DrMOS) and inductors to provide high efficiency and a small footprint, which is ideal for server applications.
The device has two independent outputs, which can be used separately or in parallel. It can achieve up to 130A (65A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC22157-A-130 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current-sensing to monitor the inductor current (IL), and has temperature-sensing to report the junction temperature (TJ).
The MPC22157-A-130 is available in an LGA-72 (9mmx9.9mmx7.85mm) package.
- Up to 130A of Continuous Output Current (IOUT)
- Temperature Sense
- Fault Reporting
- Typical Weight: 3.8g
- Available in an LGA-72(9mmx9.9mmx7.85mm) Package
MPC22157-A-130-T
MPC22157-A-130 Resources
USE CASE
MP8500APRODUCT18V, Dual-Channel, High-Current Synchronous Rectifier
