3.3V/5V, Single-Channel 2A Current-Limited Power Distribution Switch with Output Discharge
The MP62260-1/MP62261-1 Power Distribution Switch features internal current limiting to prevent damage to host devices due to faulty load conditions. The MP62260-1/MP62261-1 operates from 2.7V to 5.5V nominal input voltage and includes a 45mO Power MOSFET to handle up to 2A continuous load with a 3A typical current limit. The MP62260-1/MP62261-1 has built-in protection for both over current and increased thermal stress. For over-current protection (OCP), the device will limit the current by going into a constant current mode. When continuous output overload condition exceeds power dissipation of the package, the thermal protection will shut the part off. The device will recover once the device temperature reduces to approx 120?. The MP62260-1/MP62261-1 involves output discharge function that provides a resistive discharge path for the external output capacitor when the part is disabled. The MP62260-1/MP62261-1 is available in SOIC8 package.
  • 2A Continuous Current
  • 3A Accurate Current Limit
  • Output Discharge Function
  • 2.7V to 5.5V Supply Range
  • 90u? Quiescent Current
  • 45mO MOSFET
  • Thermal-Shutdown Protection
  • Under-Voltage Lockout
  • 8ms FLAG Deglitch Time
  • No FLAG Glitch During Power Up
  • Reverse Current Blocking
  • Active High & Active Low Options
  • SOIC8 Package
  • Output DischargeYes
  • EnableActive High
  • Fault FlagOver Current,Active Low
  • Ilimit (A)3
  • Rds(on) (mΩ)45
  • GradeCatalog
  • mps_Status1
  • Channels1
  • Iq (typ) (µA)90
  • Iout (max) (A)2
  • Vin (max) (V)5.5
  • Vin (min) (V)2.7
